Go to Post If you don't like getting tipped don't build a robot that tips. - Koko Ed [more]
Unread 23-02-2003, 00:14
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Rookie Year: 1998
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Cheapest place to get 3/8 inch ID double sealed flanged precision bearings?
As the title says, where can i get double sealed, flanged, precision bearings with a 3/8" IDfor CHEAP??
I know stock drive has them but i dont consider 16 bucks a piece cheap
thanks
TC
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 23-02-2003, 00:27
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Hrrrmmm, those are kind of hard to find. Your best bet might be the 2002 kit except those were double shielded. Also,
Boca Bearing
has a variety of high quality units that may be a little cheaper.
Unread 23-02-2003, 00:58
Andy Baker's Avatar Woodie Flowers Award
Andy Baker Andy Baker is offline
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Rookie Year: 1998
Andy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond reputeAndy Baker has a reputation beyond repute
Send a message via AIM to Andy Baker
Applied Industrial
Travis,
Try a company called "Applied Industrial". They are a manufacturer's rep, kinda like Motion Industries or Stock Drive Products.
I could not believe it, but we got this sort of bearing for under $3 each from Applied Industrial. There is a branch in Kokomo, but you should probably do a search to find your local Applied. They can get standard gears in one day (with a better selection than MSC) also.
Applied really had to look to find the cheapest bearing we needed, but they came through... I think that it was an import, packaged in groups of 10.
Andy B.
Unread 23-02-2003, 02:34
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Rookie Year: 1996
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
I think you can also get them from Small Parts for $4.75, if they have them.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 24-02-2003, 22:29
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Rookie Year: 2000
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
Double Sealed?
I'm curious why you would need the double sealed ones for our robotic applications. Unless, of course, you need them for another purpose altogether.
Unread 24-02-2003, 22:39
Engineering Mentor
FRC #0254
Rookie Year: 1998
double sealed means sealed on both sides of the bearing, to ensure they do not get dirt inside the bearing as well as keeping the grease/oil inside.
-Travis Covington
