Go to Post We have put our [robot] on a treadmill. It should shed those excessive pounds and be in shape to compete.:) - Seth Mallory [more]
Unread 23-02-2003, 21:24
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
Image Discuss: team 854's robot
Unread 23-02-2003, 21:28
mista_sparkalo mista_sparkalo is offline
#0854 (Martingrove Institute of Robotics)
mista_sparkalo is an unknown quantity at this point
We are able to stack 3 boxes if we are top loading, or stack as many as we want, if we are bottom loading. The whole mechanism tilts all the way back, so that the robot can go under the bar.
Unread 23-02-2003, 21:29
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
wow. those are huge wheels. neat arm and bot.
Unread 23-02-2003, 21:30
Clanat Clanat is offline
Custom Title
#0753 (High Desert Droids)
Clanat has a little shameless behaviour in the past
It looks like a good design, albiet with some exposed parts. How do you intent to protect them?
Former Co-Captain
Winner NW Regional 2002 and 2003
Unread 23-02-2003, 21:35
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
yeah, one good hit and that compressor is gone
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 23-02-2003, 21:40
we plan on having bumpers around at least the compressor
actually that compressor is pretty tough, we tried to get knock it off, but couldn't
Unread 23-02-2003, 21:45
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Rookie Year: 2000
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Protect the compresser. A bumper won't save it. No matter how many 'controlled' tests you've done, it will bust.
The best 'controlled' test you can do to see if you'll break it: Hit it with a baseball bat. Think it won't break from that? do it, but be prepared to buy a spare. Think it would break? Move it somewhere else.
There will be some very high impacts and a broken compresser due to poor design will mean you are not given a backup at competition.
Unread 23-02-2003, 21:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
That wet parking lot may not be the best place for expensive electronics.
Unread 23-02-2003, 22:40
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
looks to be a simple, effective design, albeit the compressor issue
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 23-02-2003, 23:02
Tony's Avatar
Tony Tony is offline
#0111 (Wildstang)
Tony is an unknown quantity at this point
Send a message via AIM to Tony
Gotta love those wheels. I'm sure you'll find a solution to the compressor issue. As for the power claim that it can pull a camry and a van...
WOW!!
If it has even a quarter of strength in that claim, that's monster power.
Best of luck!
aTm
____________________________
i'm your zero
You are Neo
You display a perfect fusion of heroism and compassion.
Unread 23-02-2003, 23:40
we will post the video of the robot pulling the two cars shortly
Unread 23-02-2003, 23:48
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
looks pretty good, we could pull about the same weight last year, but we had trouble pulling two cars since we could never get them perfectly in line. Good luck this year.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 24-02-2003, 00:50
oh, one more thing that we forgot to mention. Our robot can shift gears, by sliding the already made shifter on the drill motors.
we used a couple or modified metal pieces and the two servos under both the drills motors.
The robot shift beautifully, although we have to stop before we shift. To date we have not had any grinding of the drill gearboxes due to poor shifting. (only when the drivers were going forward while shifting.)
In high gear it will scoot around at about 3 m/s, which is pretty fast. In low, as we mentioned, it will pull a car and a van.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
Image Discuss: team 854's robot CD47-Bot Robot Showcase 1 24-02-2003 10:46
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
