Go to Post Holy cow! Five years in FIRST and it only gets better! Skyway has supplied wheels to FIRST for ten years. Ten years ago Dean called Ken for wheels. Ken said yes. Man, we love helping you guys and gals get good wheels. ;) Bart at Skywaywheels.com - SkywayWheels [more]
Unread 24-02-2003, 02:06
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Team 980 Thunder Bot's "Jaws"
With a bin in its jaws ready for stacking, the Thunder Bot is pushing more bins into scoring position.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 24-02-2003, 02:12
yangotang's Avatar
yangotang yangotang is offline
#0253 (MRT)
yangotang is on a distinguished road
Send a message via AIM to yangotang
not bad. the only thing i'd say is that if the placement of the box isn't level, would it cause the stack to be not level?
Unread 24-02-2003, 04:28
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
Team Role: Coach
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
I think that our driver picked up the bin from the top of the ramp. Since our robot was on a slant, the bin wound up somewhat slanted in the jaws. However, when we put the bin down, it settled down nicely.
Our real claim to fame is the telescoping arm attached to the top. It can rotate 360 degrees, and can be raised up to any height. When fully extended, it is quite impressive.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 24-02-2003, 11:44
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
That drive system is prety neat...
Two sets of wheels, each a different diameter. Makes it kinda like a transmission, only easier. Do you have both sets of wheels engaged together or separately? I can see slight problems if you try moving when both sets are down...
I see the levers in the middle to change the wheels... are those motor driven or pneumatic driven?
Engaging them separately wouldn't be a whole lot harder than together... just use gears instead of sprockets/chains. Though, you'd need a coupler between the gearbox and wheels to handle the shock...
For those that have no clue what I'm talking about... see how the small wheels are touching the ground, and the big one's are up in the air? It's kinda like a "poor man's transmission". Both wheels spin at the same speed, but since one has a larger circumference, it will cover a greater distance than the smaller one's. Therefore, they can engage either wheel and have a 2 speed robot. The other wheels will just spin freely. Very little power will be lost because of very little friction.
Hmmm..... this gives me a few ideas.... with the right gears, you could do the same set-up such that when both sets are down, they have high-torque, high-traction (even though the diameter of the wheels are different, rotate them at the same speed). Then, when the larger wheel is "down", it actually engages the gear of the smaller wheel, producing a higher-speed.
That'd be quite a feat, but it'd be pretty neat to see. When the faster speed is engaged it would look something like an I-Bot but with a large wheel on the bottom...
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 25-02-2003, 00:38
The wheels are shifted pneumatically. Both sets of wheels are always engaged to the drive train. There are different turn ratios for the big/small wheels (independent chain drives for each set).
The drive system shifts remarkably smoothly, even when we are under the load of another robot pushing.
I'll post a picture later that shows the drive train in a bit more detail.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
Image Discuss: Team 980 Thunder Bot's "Jaws" CD47-Bot Robot Showcase 6 24-02-2003 17:21
Team 980 "Thunder Bots" robot David Brinza Robot Showcase 2 22-02-2003 14:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
