Go to Post Careful what words you use here; we take them literally. - DonRotolo [more]
Unread 26-02-2003, 11:25
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Team Role: Leadership
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Cool 20 amp fuses for Spikes
Are the 20 amp fuses for the spike relays the same type/quality as which can be found in an automotive parts store? I had some students blow 4 or more while experimenting on last year's robot. I know that they are available via Innovation First but autozone is closer and I don't need a Purchase order.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 26-02-2003, 20:34
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
Rookie Year: 2000
ttedrow will become famous soon enoughttedrow will become famous soon enough
Re: 20 amp fuses for Spikes
The "20 amp fuses" are really self resetting circuit breakers. As soon as they cool off (in seconds) they reset and your robot starts moving again.
Tim Tedrow
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 26-02-2003, 20:38
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Re: Re: 20 amp fuses for Spikes
Tim Tedrow
Not quite. You're thinking of the circuit breakers which are inserted into the main breaker box. The question was about the single action fuses which are plugged directly into the Spike relays, from IFI.
In regard to the original question, if it fits, and it's rated at 20 amps, there shouldn't be any problem with it. You can usually find these at Radio Shack (that's where I've gotten them, anyway), but I don't doubt that you can find them at an auto parts store.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 04-03-2003, 19:35
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
more importantly what is the point in having them at all when the spikes should be connected through auto-resetting breakers. Doesn't that kind of defeat the purpose of the breakers if the fuses blow.
1139 Alumni
Unread 05-03-2003, 11:11
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
If it makes you feel safer, you can plug auto-reset breakers into the spikes, too. We usually do that, but we have a breaker shortage right now, and we couldn't get any more in time for ship.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 01-04-2003, 18:46
liquidtension55 liquidtension55 is offline
liquidtension55 is an unknown quantity at this point
we kept blowing the fuses for our compresor. we must have blown it 5-6 times.
Unread 01-04-2003, 19:25
Andy A. Andy A. is offline
Getting old
FRC #0095
Team Role: Coach
Andy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond reputeAndy A. has a reputation beyond repute
Liquid-
The compressor is famous for blowing the 20 amp fuse. I forgot why exactly.
It is legal to put a 20 amp resetting breaker (the same kind used on the distro blocks) in place of the fuse. This is only legal on the spike powering the compressor.
-Andy A.
Unread 01-04-2003, 22:11
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Originally posted by Jeff Waegelin
[b]If it makes you feel safer, you can plug auto-reset breakers into the spikes, too. [b]
Can you provide a rule or a FIRST forums posting that says that? As far as my memory goes, the only fuse you can replace with a auto-reseting circuit breaker is the one that the compressor uses. (And apparently, Andy A. agrees with me).
Unread 01-04-2003, 22:18
El Jefe de 148
I don't know if it's in there or not (allowed or disallowed). I just know we've done it in the past. We didn't this year, since we didn't have enough 20 amp auto-resets, though.
Jeff Waegelin
120 amp breakers...? viper Electrical 4 24-01-2003 14:38
60 amp Circuit Breaker Info archiver 2001 1 23-06-2002 22:33
Blowing 60 Amp fuse archiver 1999 4 23-06-2002 22:07
Where can I get 60 Amp Fuses -- that look like 30 Amp Fuses? Anton Abaya Chit-Chat 4 12-01-2002 14:09
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
