Go to Post This wins this week's award for "Most Bizarre Thread". Carry on. - DonRotolo [more]
Unread 26-02-2003, 15:58
Gun Gun is offline
#0253 (MRT)
Gun is an unknown quantity at this point
Modifying Motors
i need to know how to modify the motors so as to let them slip so they dont make a grinding noise.
Unread 27-02-2003, 14:51
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
You may not modify motors except as listed below. The motors have distinctive noises that are not an indication that anything is wrong.
M15 The motors in the kit may not be modified except as follows:
· It is acceptable to modify the mounting brackets and/or other structural parts of the motors (output shaft, housing, etc.) as long as the electrical system is not modified and the integral mechanical system of the moving parts (bearings, bushings, worm gear output stages, etc.) is not changed or removed.
· The gearboxes for the Fisher-Price, Drill, and Globe motors are not considered “integral” and may be separated from the motors. FIRST will not provide replacement for parts that fail due to modification.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 27-02-2003, 15:11
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Re: Modifying Motors
Are you referring to the dril motors? If so the "grinding" you are probabaly hearing is the clutch slipping. There are instructions on this forum on how to lock the clutch. Do a search.
Please explain what you are referring to.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Urgent...Modifying this years drill motors Mimi Brown Motors 17 07-01-2003 23:04
Looking for practice motors & extra tape drive parts? archiver 2000 1 23-06-2002 22:54
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Drill Motors TF8 Motors 19 12-12-2001 13:13
