Go to Post F.I.R.S.T. Troubleshooting Rule #1 - If you work on software, the problem is always with hardware. If you work with hardware, the problem is always with software ;) - Redneck [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 26-02-2003, 19:08
Chris Dibble Chris Dibble is offline
#0102 (Gearheads)
Chris Dibble is an unknown quantity at this point
Send a message via ICQ to Chris Dibble Send a message via AIM to Chris Dibble
Angry Major Inventor Problem
I've been using Inventor to design the robot, and am nearly finished. But recently, I've gotten an error which does not let me save! Here it is:
[WARNING] Problems encountered while saving the document. <FwRes.dll(1806)> [r:\core\Fw\Main\FWxSceneDoc.cpp, line 1431]
[ERROR] Error(s) detected while writing segment AmDcSegment in database C:\Documents and Settings\Dibble\My Documents\Chris\Activities\Robotics\Inventor\Robot \Robot Built Frame CTD2.iam <RSeRes(622)> [r:\core\RSe\segment\segStream.cpp, line 242]
[ERROR] Error detected while saving object of type RDxOccurrence <RSeRes(1408)> [r:\core\RSe\meta\meta.cpp, line 967]
[ERROR] Internal error in persistence operation (Segment loading is not supported within other persistence operations) <RSeRes(623)>
[ERROR] The database in C:\Documents and Settings\Dibble\My Documents\Chris\Activities\Robotics\Inventor\Robot \Robot Built Frame CTD2.iam could not be saved <RSeRes(202)> [r:\core\RSe\database\databaseC.cpp, line 1195]
Does anyone know why this is happening? I'm running on a 2ghz machine with 512mb ram, so it shouldn't be processor speed.
Please help if you can, I'll greatly appreciate it.
Thanks,
Chris
