Re: Hmmm
I think suction cups will prove to be a determing factor this year. |
But back to the point I was trying to make, the amount of force that a bot has going 12 FPS weighing 130 pounds far outweighs what ive seen in the suction cups. I also think that even if a robot that was rammed at full speed into a robot secured with suction cups *IF* they even to withstand that kinda punch, There seals would for the most chances break.
Suction cups will work good for the first few practice matches and maybe some into the qualifying but by the time finals hit that HDPE will look like a scratching post covered in dust, dirst, and oil. Everyones pro-suction point is saying they can withstand exert a huge force on a glass-smooth surface, chances are the HDPE will be more like a rough concrete. If teams still want to go with suction cups it seems logical to go with 20 small ones instead of 1 or 2 large ones to minimize the risk of trying to lock onto an area with a scratch.
Do you want to take the chance that during finals your bot trys to lock onto the joint between the 2 pieces of HDPE and another bot knowcks you off like you weren't even there? Also Ramp-doms have to stay for nearly the entire 2 minuts and even if the scratches only allow a slow leak chances are the ramp-dom would have to re-attach every so often. The best option is to put some _ _ _ _ _ _ _ _ breaks on the bottom of your bot and get a COF of about 2.0 or if your budget allows and you can find it get some _ _ _ _ _ which will give you a COF of about 3.5. Friction brakes are more reliable and lighter. |
Just remember- you have to be on the top of the ramp to use your suction cup...
if you aren't first.. tough luck.. |
Also found this Quote:
im liking the idea of suction cups even more at every moment
45's suction cups are sweet. meant for load paralell to the attaching surface, they should hold very well. |
wouldn't it really be from what kind of suction cup you used? If the suction cups had a very large edge to them, spare material they might hold. Think like a dinner plate, the indented area being the suction cup. There is a wide lip around the whole thing, now if that was wide enough, say maybe 3 inches of just extra material where it met the floor it could probably compensate for short 2 inch marks because the extra material would completely cover all the short ones that got under it at all and those that started midway wouldn't have access to the vacuum inside. Our team did not have an opportunity to make an entire ramp top to see how long the usual marks are or how deep they are but I'm guessing they might be deep but short meaning that might be a solution. Dust might be a problem but I don't think many robots will be dumping chain grease everywhere for the simple reason that they would work hard to fix that for the safety of their own electronics panel if nothing else. Any team that didn't wouldn't be playing many matches in which they got on the ramp anyway.
I completely admit this is all in the wonderful world of logic which often has nothing to do with the real world, please tell me how far from reality any of it has gone in your experience. |
that is a pic. of my teams suction cups and there are two 300 pound suction cups, totaling a 600 lb vacuum. Dont believe me? No robot in two regionals could move us and robots actually bounced off our bot, in fact there so effective that in order to get the robot up at the end, we have to depressurize our pnuematics.
#10
Only FIRST sparks so much discussion about suction cups
#11
If anyone cares, I must point out, that suction cups is what won the regional at SBPLI, 2 out of the 3 teams used them, ourselves and one of our alliance partners. We would simply go to the top of the ramp, suction down, not be moved, and theres 50 points right there, kinda hard to come back with 1 bot and no multipliers
#12
Easy Way to win against suction cups
I might point out that the only way the suction cups will work is like OneAngryDaisy said you have to make it to the top of the ramp to suction down. In the Florida Regionals we were up against a team with good suction cups but we wouldn't let them get up to the ramp.
#13
Awesome... I can't wait to see them in action...
#14
#15
| The Death of FIRST | Anton Abaya | General Forum | 23 | 03-05-2006 17:18 |
| pic: Team 870 Wiring Nightmare | CD47-Bot | Robot Showcase | 15 | 02-03-2003 21:46 |
| The 2003 Index of team's post about their robot... | Ken Leung | Robot Showcase | 4 | 28-02-2003 00:18 |
| pic: Team 870 Front Drive Train | CD47-Bot | Robot Showcase | 4 | 27-02-2003 15:23 |
| pic: Team 870 Rear Drive Train | CD47-Bot | Robot Showcase | 2 | 27-02-2003 00:22 |
