Parts need for Autonomus
My team want to add autonomus on our robots can someone pelase tell me the parts adn what i need to do to add it
Remember that big blue MSC book? On page 1198 there are some pneumatic grippers used to operate the switch between driver and autonoumouse mode. Don't worry though as they are only $348.46 apiece and very eaisy to install. You will need two.
Awwww, I'm just joking. It's all in the program so you really don't need any parts. You may use sensors or encoders if you wish. |
You will probably will need a 3 way switch or 2 way depending on how many Autonomus modes you are looking to add.
For example: 1- Dead Rec. Left 2- Dead Rec. Right 3- Go crazy and attack the audience ![]() OR- You can just program the robot between matches on which program you want it to run. |
Re: Parts need for Autonomus
Autonomous control is a mode of the robot. Where as a program tells it what to do (Drive forward until something happens, then turn, wait 2 seconds, turn again).. and so on without the joysticks being touched. You don't need parts to do this, unless you mean to test autonomous mode. In that case all you need is a small insulated wire or a pair of wires and a switch. Stick one end of the wire into pin 1 of the competition port, and the other end into pin 4. If you use a switch, do the same thing and flick the switch to allow a connection across the wires. |
You can send me an e-mail at miketwalker@cfl.rr.com if you need help figuring out what to do. Also, check out the tutorial I wrote up on our website. It shows how to make a dead reckoning robot code. I can also show how to do an optical sensor scan if you mount them and put them into your digital inputs. I just haven't written a tutorial for that yet. Good luck!
| Rules on making spare parts fyi | DougHogg | General Forum | 0 | 02-04-2003 16:18 |
| Calling all Lawyers... ...Define "all parts" | Joe Johnson | General Forum | 10 | 13-03-2002 15:12 |
| Anyone else crippled by no supply of parts? | aka Scott White | General Forum | 11 | 31-01-2002 10:52 |
| What advice would you give? | Jessica Boucher | General Forum | 8 | 02-12-2001 07:10 |
| Substitute Parts | BHSFirst | Off-Season Events | 1 | 08-11-2001 19:23 |
