Go to Post I say we all stop flaming and pointing out what went wrong or what bad calls were made and start pointing out how much fun we all have at the regionals and what FIRST actually has done for us. - burkechrs1 [more]
Unread 03-03-2003, 09:06
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
Pump operation before match
Does anyone know how to make the compressor turn on before the start of the match? We would like to have our compressor be charging before the match starts, but I can't figure out how to do it. I know we did it last year, but I can't for the life of me remember how I did it last year. Can anyone help me with this?
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 03-03-2003, 09:16
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
As far as I knw, the pump should have been driven from either a Spike or Speed Control which would not have ad a PWM signal before the start of the match!? So I don't think it should have been running before the match but you can precharge the pneumatics system in the pits before you place your robot on the field. We will be doing this as we don't have the compressor on-board the robot
Unread 03-03-2003, 09:34
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
I'm assuming you want to charge your air tanks before he match starts so you are not wasting time trying to charge them during the match. To do this, simply hook up the compressor to a spike relay, and program it to be on all the time. The pressure switch will turn the compressor off at approx. 115 psi.
Unread 03-03-2003, 09:38
Unsung FIRST Hero
Nate Smith Nate Smith is offline
FRC Key Volunteer Trainer
AKA: CrazyNate
Rookie Year: 1998
Nate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to behold
Send a message via AIM to Nate Smith Send a message via Yahoo to Nate Smith
Re: Pump operation before match
Due to the requirement of having to run the compressor through the Robot Controller, there is no legal way to have the compressor charging while the control system is disabled. However, it is possible, as has been mentioned already, to pre-charge the tanks before you place your robot on the field, using the tether connection in the pit area...
Nate Smith
nsmith@smythsoft.com
12 seasons, 4 teams, and more time logged behind the scorekeeper's table than I care to remember...
returning for 2011? only time will tell...
Unread 03-03-2003, 13:12
El Jefe de 148
Yeah, that was our plan up to this point. I guess we'll just have to live with pre-charging.
Jeff Waegelin
Unread 03-03-2003, 15:46
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
Last year with the Red relays you could have done it if I understand correctly that the Red relays where normaly closed switches, but what does it matter, no Red relays this year.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Unread 03-03-2003, 15:54
Rookie Year: 1999
From the Spike Manual for RED
Table 1: Spike Red P-BASIC software control, Spike output, Motor function
INPUTS OUTPUTS
Fwd Rev M+ M- Indicator Motor Function
0 0 +12v +12v Orange OFF / Brake Condition (default)
1 0 +12v GND Green Motor rotates in one direction
0 1 GND +12v Red Motor rotates in opposite direction
1 1 GND GND Off OFF / Brake Condition
It appears that with no PWM signal 12V would be available at both terminals, so unless you put the pump to only one terminal and the other side to the ground, it shouldn't have worked on the RED spike either. (No voltage difference between Black & red on the pump)
I think the intention of the Control System is not to have any outputs functional when the Control System is Disabled
Unread 03-03-2003, 16:19
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Rookie Year: 2000
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Either precharge your tanks using the tether cable or you could do what some teams have begun to do and just build a tank charger using a pump , battery, fuse and some kind of switch. Just open up your main relief valve and pump preasure into the system then when you get to 120 shut the valve and unplug the external pump. That way you start with fully charged tanks so your pump doesn't have to waste time charging them.
I hope i explained that clearly enough. We are working on finishing out external pump assebly tonight and i'll post pictures when its done.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 03-03-2003, 17:38
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
A good pneumatic system without the slightest air leak would do fine with precharging, as all the air would stay there Unfortuneately, for most of us, it leaks a tiny bit, so I suggest charging it as late as close as possible to the match time.
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 03-03-2003, 17:56
El Jefe de 148
INPUTS OUTPUTS
Is there something like this available for the Spike Blue?
Jeff Waegelin
Unread 03-03-2003, 19:13
Rookie Year: 1999
Why yes there is: (From Innovation FIRST Website)
Table 1: Spike Blue P-BASIC software control, Spike output, Motor function
INPUTS OUTPUTS
0 0 GND GND Orange OFF / Brake Condition (default)
1 1 +12v +12v Off OFF / Brake Condition
Unread 03-03-2003, 19:29
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
whoa i never knew the spikes brake.
1139 Alumni
Unread 03-03-2003, 19:49
Rookie Year: 1999
Brake = Connect both leads together
Unread 03-03-2003, 20:01
rust710's Avatar
I wish I knew that about the spikes last year. Could have been very useful.
Andrew Radamis
Programmer on 862
  #15   Spotlight this post!
Unread 04-03-2003, 09:00
El Jefe de 148
So, in theory, could you accomplish what I'm thinking of by using a red spike and hooking the black wire of the compressor directly to ground? I'm already thinking it's not a good idea, but would that theoretically work?
Jeff Waegelin
Thanks 968 and 294 and last match LA sanddrag Regional Competitions 5 16-04-2003 17:15
How should FIRST Replay a match Matt Reiland Rules/Strategy 4 09-03-2003 11:11
Sound Levels Measured at the Nationals archiver 1999 8 23-06-2002 22:47
Thanks - Wild Stang - What a match!!!!!! archiver 1999 1 23-06-2002 22:15
Pneumatics pump allowed on robot? bigqueue Pneumatics 5 06-01-2002 12:30
