Go to Post Thinking can be uncomfortable, but I always think that it is beneficial. - JaneYoung [more]
Unread 04-03-2003, 09:17
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
Originally posted by Jeff Waegelin
So, in theory, could you accomplish what I'm thinking of by using a red spike and hooking the black wire of the compressor directly to ground? I'm already thinking it's not a good idea, but would that theoretically work?
Theoretically I can't see why it would not work, the pump would be on any time that the relay fwd or rev were set to 0 (Depending on which you wired it to) Strangely I can't find it in the rules where it states which devices can be tied to the GND Blocks.
Here is what it says:
Except as noted herein, each Ground (GND) wire from a speed controller, relay, or Robot
Controller must go directly from that item to one of the 12 Common (-) terminal tabs on the
circuit breaker/ fuse blocks.
Exception: The Ground (GND) wires from low current items such as solenoid control and
rotating light relays, custom circuit, optical sensors, LEDs, and fans may be connected as a
group to one common wire leading back to a Common (-) terminal tab.
But it doesn't specifically seem to say the output side of the spike or speed control to the motor, however the exception is for low current items only. Either way the RED is no longer available so it doesn't matter much.
Unread 06-03-2003, 16:07
Lloyd Burns Lloyd Burns is offline
FRC #1246 (Agincourt Robotics)
Rookie Year: 1997
Lloyd Burns is an unknown quantity at this point
And last year, with red spikes still allowed, all you needed to do was have the compressor connecter to a Red (+) and a Blue (-) Spike, to have it turn on. As long as no one caught that you were using the different types of Spike, and as long as no one insisted that the compressor be connected with both leads to the same Spike.
Alas that is (and Red Spikes are) unavailable to you this year.
Unread 19-03-2003, 10:28
IronSlayTallica IronSlayTallica is offline
IronSlayTallica is an unknown quantity at this point
Try having a spare battery, preferrably an old one used just for charging the tanks before the match. Just keep it outside the robot and plug it in the way any normal battery would be used. Have the compressor set to be run all the time and it'll switch off around 120 psi. Once that's done, plug the regular battery back in and you're ready.
Unread 19-03-2003, 11:05
KenWittlief KenWittlief is offline
KenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond reputeKenWittlief has a reputation beyond repute
If there is anything running on your bot before the match begins (before FIRST enables the controllers) your bot will be disqualified.
You cant jury rig the wiring to bypass the intent of the judges match Start/Stop switch.
If you did this, you could also have motors and other actuators running before or after the 2 minute period.
Keeping your tanks full before the match is part of the challenge. make sure all your fitting have teflon tape properly used - all fitting are good and snug (the BIG grey solonide requires you to use a Hex wrench inside the fitting to tighten it)
and make sure all your hoses are pushed in, then pull them out firmly to seat them.
If your pnumatics leak then your bot is not properly assembled - you cant play well will a poorly assembled bot
if you are going to break the rules, you might as well break all of them, right?
Unread 29-04-2003, 09:42
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Rookie Year: 2000
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Here is a picture of our external pump that i said i would post:
http://www.chiefdelphi.com/forums/pi...&quiet=verbose
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Thanks 968 and 294 and last match LA sanddrag Regional Competitions 5 16-04-2003 17:15
How should FIRST Replay a match Matt Reiland Rules/Strategy 4 09-03-2003 11:11
Sound Levels Measured at the Nationals archiver 1999 8 23-06-2002 22:47
Thanks - Wild Stang - What a match!!!!!! archiver 1999 1 23-06-2002 22:15
Pneumatics pump allowed on robot? bigqueue Pneumatics 5 06-01-2002 12:30
