Go to Post While in the Navy, we had an apparent leak in one of our systems and it took me 7 months to track it down. Just because you haven't found it, doesn't mean it doesn't exist. - TubaMorg [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 17-01-2002, 22:04
Trashed20's Avatar
Trashed20 Trashed20 is offline
Boom, Shawalala Boom!
#0862 (PCEP Lighting)
Trashed20 will become famous soon enough
Send a message via AIM to Trashed20
Exclamation Cell or Cartoon Shading?
I just installed our team's software and i was wondering if there was a way to achieve cell or cartoon shading. I don't really want to buy a plugin. any suggestions?
Where has all the fun gone?
Unread 17-01-2002, 22:36
Zeinin Zeinin is offline
#0449 (Blair Robot Project)
Zeinin is an unknown quantity at this point
Send a message via AIM to Zeinin Send a message via Yahoo to Zeinin
max should have a built in one
lightwave has 2
1.4 gzh athlon TBIRD
512mbs ddr
GeForce 3
SBLIVE 5.1
Unread 17-01-2002, 22:39
Trashed20's Avatar
where is it located? environmental effects, material editor, where? do we get a copy of lightwave by the way?
Daishichimaru Daishichimaru is offline
Daishichimaru is an unknown quantity at this point
Send a message via AIM to Daishichimaru
I'm pretty sure there's an option or two in the render flyouts, but VectaMAX'll do flat shading. Don't ask my how, since I don't clog my HDD with stuff I don't need, but it does.
Unread 17-01-2002, 22:49
Trashed20's Avatar
i can't find it anywhere
Unread 18-01-2002, 00:23
Robby O's Avatar
Robby O Robby O is offline
no team (Volunteer)
Robby O is an unknown quantity at this point
Send a message via AIM to Robby O
You simply need to change out your renderer. Press SHIFT+R and that will open the render dialog. Now scroll down until you see a flyout called CURRENT RENDERERS. Click ASSIGN and select the renderer entitled VECTA 3D. This should add a flyout bar called VECTA 3D RENDERER that should be automatically expanded. If not, expand it by clicking on the bar. You can choose to either output to a file or the screen, with the files being either FLASH or ILLUSTRATOR. And then mixing and matching render styles will hopefully give you the look you're going for.
As for me, I dont really like Vecta 3D unless I need a Flash or Illustrator file. There are a few 3rd party plugins that work better but cost a pretty penny. Cartoon Reyes is one, and another would be Illustrate, which I prefer as It has quite a few options to really achieve the look you want. That and I think that for only $99 smackers, you can get an educational copy. But dont quote me on that... B^P.
Hope this helps, good luck, and happy animating!
-Robby O
FIRSTanimators Moderator
oshortwan@hotmail.com
Hope that helps. Good luck and happy animating!
-Robby O
"If I had it in me
To stop these random thoughts
And non-stop dreams
I could deal with this
Non-stop spinning world" -Less Than Jake
Unread 01-02-2002, 23:26
Funkymunkey90's Avatar
Funkymunkey90 Funkymunkey90 is offline
Funkymunkey90 is an unknown quantity at this point
Cell shading is simple here is a base material to use
It is just using the falloff and a basic material
Team 384
Animation Team Captain
Joy of Tech Segway cartoon rolocroz Dean Kamen's Inventions 0 28-01-2003 15:37
Segway seen in Blondie cartoon team222badbrad Dean Kamen's Inventions 5 26-08-2002 00:56
Old school cartoon! Elgin Clock Chit-Chat 2 07-02-2002 06:22
