Go to Post Being a good engineer isn't all about engineering. It's about being able to use engineering for a practical application, and to successfully communicate your research or development results to people who aren't engineers - Jon Stratis [more]
Unread 18-01-2002, 07:08
John Larock John Larock is offline
#0365 (DuPont Miracle Workerz)
John Larock is on a distinguished road
Question NEED HELP - Goal Weight
Hi all. Hope everyone's doing well as we near the end of week two.
QUESTION 1 - Have any teams found a discrepancy between the actual weight of a goal your team constructed and the weight FIRST communicated - 181 LBS?
We constructed goals based on the BOM and updates, weighed each by hoisting onto an industrial scale, and we continually come up with between 130-135 lbs.
QUESTION 2 - If your goals do come close to 181 LBS, how did you weigh it? Are your materials the same as FIRST has specified on the prints?
Thanks in advance for the help!
John Larock
Team 365 - Miracle Workerz
John
Unread 18-01-2002, 07:56
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Re: NEED HELP - Goal Weight
John Larock
We (Team 811, BG-MIT/LL) built the goal and ours came up to 172 pounds. i believe we built it exactly to specification, but I don't think we were dismayed by the fact that we were about 5% off the spec' weight.
We weighed our goal by hefting it up onto a spring scale hung from an I-BEAM in the ceiling. I am not sure how accurate these scales are, but this could have been the difference right there. (Actually, now that i think of it, we did not have the retroreflective tape....but that's probably negligable)
I think your 135 lbs sounds suspect (25% lighter than usfirst claimed)....if you built it to specs, you might want to look at your method of weighing it....perhaps do some "tests" by building a 50/50 sea-saw and placing various students and adults across from a goal to see which ballpark it really live in.. ..135 lbs or 181 lbs.
Good luck,
-Quentin
Live free or die....
Unread 18-01-2002, 12:05
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Rookie Year: 1999
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
if you are absolutely sure...
If you are absolutely sure that you are using the same stuff as the Bill of materials, and that you are not missing anything on the goals, then I suggest you still find some ways of adding weights onto the goals. Just put on whatever weights you can find to get the goals to 181lbs. I am sure you can expect the goals at competition to be this heavy, so you might as well do that to make sure your robot have the thing to test with.
The weight of the goal mostly came from the 16 steel nipples, the flanges that's holding those nipples, the steel bracket around both the deck, and the two ply wood pieces themselves... And probably all the casters. Just make sure you have all these on your goal.
Unread 18-01-2002, 22:05
Dr.Bot
Posts: n/a
There probably is a lot of variation in the weight of the pipe flanges - they were so hard to get in San Jose that we have 4
different kinds on our goal - since they probably can be a couple of ounces different in weight - this times 32 can be a 10 to 20lb
difference - same thing goes for the iron angle - if you ommitted it
or used aluminum instead - that probly id another 10 to 20lbs diff.
SO if your really worried add some weight to the bottom!
Unread 19-01-2002, 08:38
Lloyd Burns Lloyd Burns is offline
FRC #1246 (Agincourt Robotics)
Rookie Year: 1997
Lloyd Burns is an unknown quantity at this point
The one constructed for the Kickoff here weighed in at 178 pounds, I'm told.
Unread 20-01-2002, 23:05
AdamT's Avatar
AdamT AdamT is offline
#0401
Rookie Year: 2000
AdamT is on a distinguished road
We used everything exactly to spec (sadly enough even the Ralph Lauren brand paint) and ours seems to be close. i don't know an exact weight, but If your's isn't anywhere close and you're sure all of the nipples are the right distance apart and the only thing wrong is the weight, then just put some cement blocks on it or something to add enough weight. Problem solved.
Unread 21-01-2002, 06:52
Wink RESOLUTION
Thanks for the responses! We went through the BOM and *almost* everything matched. We also used a different method to weigh the goals.
After all was said and done, the weight was more in line - in the 170-175 lb range.
So, we are off and running.
Hope everyone is getting *some* sleep.
-J-
John
Unread 21-01-2002, 08:40
Jordan A.'s Avatar
Jordan A. Jordan A. is offline
#0781 (Kinetic Knights)
Jordan A. is an unknown quantity at this point
Send a message via ICQ to Jordan A.
As far as getting the flanges, our team lucked out. Country Depot (a store I thought only sold seed and lawnmowers) actually had them IN STOCK.
They gave us a great deal for them too.
FIRST and Success: A Question of Definition Madison General Forum 70 27-11-2002 08:42
Small balls in 2001 competition archiver 2001 10 24-06-2002 03:59
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
Just curious, how many robots could shoot or toss balls into the goal? Alan Ing General Forum 7 13-05-2002 19:09
