We ordered some Digi-Key optical encoders for use on our robot's stacking mechanism (for automatic positions). However, we have run into a snag in programming these little buggers. We have hooked the power up to the +5V for Potentiometers on the Analog Inputs, and the ground wire to this port as well. Then, we hooked Inputs A and B onto digital inputs 15 and 16, respectively. Our problem is that all the readings we get on a debug are zeros. Any ideas? Thanks.
| Programming Compatition | Angela06 | Programming | 30 | 08-04-2005 23:12 |
| Q&A Discuss: optical sensors | CD47-Bot | Extra Discussion | 0 | 15-02-2003 22:58 |
| Pneumatics electrical wiring and programming | archiver | 2001 | 1 | 23-06-2002 23:10 |
| Error found in programming for the pump and pressure switch | sjharobotics | Programming | 4 | 06-02-2002 17:46 |
| pbasic programming | punarhero | Programming | 4 | 21-01-2002 23:32 |
