Go to Post It can't be too bad... it's Canada! :) - Brandon Martus [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 08-03-2003, 02:00
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
Parsing usfirst Match Data
Hey all... Just up at this ungodly hour of 2:01 AM ( - 201 = My team number) making a nice little script to parse match data from usfirst.org
Attached it is (zipped because I can't attach a php file duhhh...)
You're going to need a web server that has php to be able to run this script. Also, I have no idea of how they're going to handle the finals, so the odds are i'm going to need to change this tommorrow when i see the formatting for the finals.
Anywho, here it is. When you call the script, you'll need to include the url that the data is on.
Ex: http://127.0.0.1/matches.php?url=URL...RST_MATCH_DATA
a valid url to go to would be: http://www2.usfirst.org/2003comp/eve.../matchsum.html
Anyways, I'll just echo the results to your browser. However, i made a comment on the line in which you would add an sql statement to insert into a db. Also, if a match has not yet been played, it won't be displayed/outputted.
Once again, I'm guessing i'll need to change it after they post the finals, but here it is for now. If you have any questions, feel free to contact me. Once the first set of regionals have all their data on the web, i'll post csv files of the match results. They all will also be on http://fbi.feds201.com
Jack
PS: Thanks to Brandon for his help
File Type: zip matches.zip (866 Bytes, 51 views)
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
[IMG] code is Off
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 20-01-2003 16:08
Competition Scouting pauluffel Scouting 31 09-01-2003 00:34
Robot Scouting Database archiver 2001 10 24-06-2002 03:00
Limiting PWM in pbasic archiver 2001 4 24-06-2002 00:38
Sound Levels Measured at the Nationals archiver 1999 8 23-06-2002 22:47
