Go to Post Gravity is not always pointing the same direction relative to the robot! - ChrisH [more]
Unread 08-03-2003, 17:25
Jay05 Jay05 is offline
Jay05 is an unknown quantity at this point
Question Terminal Screw Strips?
Hey everyone....
After todays events at VCU I am looking for a way to securely connect all wires on our robot. We currently solder all crips and use spades to connect all components...
I would like to, however, use screw terminal strips for any connections needed. Another older team member said that this violates the rules. I can't find any rule except the one that states..
the 6AWG battery wire must have a direct path between the battery and fuse panels.
Is a terminal strip considered a legal electrical path by FIRST?
Any teams use screw type terminal strips??
Thanks and yes i did search first before posting
Jeff
Fischer Price mounting screw ateene Motors 1 09-02-2003 21:00
Metal strips on ends of bridge archiver 2001 2 23-06-2002 23:35
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
