question about atwood motor
Does anyone know where you can purchase 25 degree pressure angle gears to mesh with the atwood motor output shaft? (other than the one we were supplied with)
That was why you were supplied with it
. Sorry, but it is not a common pressure angle. The other part of the cluster _is_ a common gear and you can interface with it.This means that you will need access to machinery to mount the motor, the shaft for the gear cluster and at least one other cluster. You may have to to a machinist to have it done. Larry Barello posted a picture of a trial run he did, and some useful dimensions. Good Luck |
| Drill motor change out question?? | archiver | 2001 | 9 | 23-06-2002 23:36 |
| Is it weird to see an atwood motor floating in mid air? | mnkysp6353 | Chit-Chat | 6 | 19-02-2002 21:38 |
| What's with the New Motor Specs for the Atwood Mobile (Chiaphua) Motor. | Robb Gerber | Motors | 2 | 23-01-2002 08:58 |
| question about atwood motor | matt sorgenfrei | Motors | 0 | 18-01-2002 23:19 |
| Drill motor gearBox question | Dennis Hughes | Motors | 4 | 11-10-2001 07:11 |
