Go to Post What makes a team great is not what they do during the 6 weeks, but what they do the rest of the year. - davidthefat [more]
Unread 12-03-2003, 08:24
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
Question about using the "brake" on the 884
Have any of you noticed any real evidence of damage or extra wear-and-tear on the Victor 884's when the "brake" feature is used? Also...Would using the brake make a dead reckoning robot behave more like it is supposed to (the robot would stop when you tell it to)?
Unread 12-03-2003, 08:29
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Rookie Year: 2000
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
Our team has not noticed any extra wear and tear.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 12-03-2003, 08:33
AKA: aXvXiA
Okay...here's another question: If the brake is on, will changes in the PWM input from 254 to...say...160 actually make the robot's speed reflect the change in speed? In other words: Will the brake help force the motors to go to the correct speed when they are slowing down?
Unread 12-03-2003, 08:38
Rookie Year: 2000
Ummm
Its to early in the morning for me to think...
I'll post a response during 5th hour...
Maybe Al or one of the more knowlegable people on here can post a response before me. They probably know more then me anyways.
Unread 12-03-2003, 08:39
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Brake will not change the behavior of the robot when going from 254 to 160. It only takes affect when the output is 127. It shorts the motor leads, and the motor stops much much more quickly. You may see a slight difference when switching from foward to reverse (becasue it crosses 127), but you should only see it when stopping.
Using brake does put more wear and tear on the victor, because it has to deal with the back emf from the motor. However, the victor was designed to deal with it, and so it shouldn't be a problem. If it does cause a problem, then it is a design or manufacturing flaw, and you should get it replaced from innovation first.
Unread 12-03-2003, 09:08
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
I know it made our autonomous program work better. Without it, we rolled about 4 or 5 feet extra, but with brakes, we stopped in less than a foot. There are a few problems, though. We've experienced some backflow of current when the motors stop, and it throws our program off a bit. We've since solved that problem, but it was very annoying during testing.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 12-03-2003, 13:51
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
The 884's are not damaged and do not wear from the use of the braking function. As stated above, in "brake", the Victor produces a low resistance connection across the motor (which is now acting like a generator) and all of the robot motion is turned into electrical current which is shunted by the 884. If the brake mode is affecting anything on the robot, it is possible you have a high resistance somewhere in the wiring. Check for loose connections/crimps particularly in the negative side wiring for battery and power distribution.
Al
WB9UVJ
www.wildstang.org
________________________
We fried an 884 Andrew Electrical 13 17-08-2003 23:02
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
