Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
Unread 13-03-2003, 12:05
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Arm vs Arm
pic: Robotic arm CD47-Bot Robot Showcase 2 14-09-2003 17:37
pic: Team 980's arm hitting the stack at 2 seconds on clock CD47-Bot Robot Showcase 29 01-04-2003 21:48
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
Correction for arm skyfw Programming 6 06-04-2002 21:59
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
