Go to Post Remember, everything you do while on the team reflects on your team. Good reputations are difficult to build and easily destroyed. - Daniel_LaFleur [more]
Unread 16-03-2003, 19:16
DKolberg DKolberg is offline
Mentor Iron Giants
AKA: David Kolberg
FRC #5069 (Iron Giants)
Rookie Year: 2000
DKolberg has a spectacular aura aboutDKolberg has a spectacular aura about
Question PB_Mode Sequence
Question for others: What is the correct sequence for the Comp_Mode and Auton_Mode? We thaught it should have been:
Comp_Mode = 1, Auton_Mode = 0 => disabled, Human Mode
Comp_Mode = 0, Auton_Mode = 1 => Autonomous Mode
Comp_Mode = 0, Auton_Mode = 0 => Manual Mode
Comp_Mode = 1, Auton_Mode = 0 => End of Match
Further the sequence would be Auton_Mode would be set to 1 before or at the same time as Comp_Mode = 0. We found at the Pitt comp that Comp_Mode went to 0 prior to Auton_Mode going to 1. We had to add commands to enable auto mode from Manual Mode. Has anyone else found this problem?
Dave
RC bootup sequence Venkatesh Programming 17 18-11-2003 20:56
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Clips of the Closing Animation Sequence from the Nationals? archiver 2001 0 24-06-2002 04:11
