Go to Post Remember everyone, during build season, if you mess something up..... In the words of Adam Savage... Failure is always an option! (and so is blowing stuff up) - J.Warsoff [more]
Unread 17-03-2003, 19:51
Thunder360 Thunder360 is offline
#0940 (Digital Demolition)
Thunder360 is on a distinguished road
Gears
Hey guys Im puting together some Idea's about next years drive train, and I dont have a clue how fast our bot would go with my current set up. So if somone would be nice enough to run these #'s and tell me about how fast we will be going that would rule. We are prolly going to run a Chippy with a 10 tooth gear, then to a 20 tooth gear, on tht same shaft we will have a 10 tooth going to a 25 tooth. On that shaft we will also have a 10 tooth gear going to a 60 tooth gear connected to 2 wheels. So it will be 4WD when both sides are put in, so ya some #'s like speed would be nice, if you have and more questions I can E mail you the lay-out I made.
"Who needs Battle Bots, Ive got US FIRST!!!"
Unread 17-03-2003, 20:07
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
What wheel size were you thinking of using? It looks to me like your final gear ratio will be 1:30 with somewhere in the vicinity of 75-85% efficiency (assuming 92-95% per stage). So, given the ~4500rpms of the chips under normal load, you're looking at around 2 rotations per second on your wheels. Multiply this by your circumference and you'll have a rough estimate of your speed. Assuming 6" wheels, that comes out to around 3fps. While this is very slow, you would have a lot of torque. On the other hand, bigger wheels would result in faster speeds (at the cost of torque) while smaller ones would result in even slower speeds.
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
Unread 17-03-2003, 21:58
thanks that really helps, we were looking at either usind the Skyway Tuff wheels or the big honking wheels that were used 2 years ago, prolly will stick with the Skyway's. Thanks again
Regional & Division winners, did you shift gears or not? DougHogg Technical Discussion 34 02-05-2003 16:10
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
gears....? archiver 2000 16 23-06-2002 22:58
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
