Go to Post The championship event is a meta-game of inches. People will complain about unbalanced/unequal divisions, whether you think it's silly or not. - PayneTrain [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 19-03-2003, 20:23
Psy Guy Psy Guy is offline
#0617 ((not named))
Psy Guy is an unknown quantity at this point
Send a message via AIM to Psy Guy
Question Less lag animation.
Hello
I have just joined the forum and i hope to be able to share knowledge with the rest of you that are here anyway.
Im a "beginner level" animator with a general knowledge of 3ds Max and some experiance under my belt. I am working on an animation project (personal project) which is rather large to say the least. Anyway the question is what method is good for making fair grade character models that look nice but doesn't lag the computer when working on it? I have a tendencey make complex character models which slow my comp down to a crawl.
-PSY GUY-
"If only I could use duct tape to fix my animations"
Unread 20-03-2003, 07:49
Soukup's Avatar
Soukup Soukup is offline
Animation Guru
AKA: David Soukup
Soukup is on a distinguished road
if you could post your specs of your computer that could help a little.
There is no right way to make a character, and I know of only one way, but something that we did with our character this year is when we were done we optimized it. (this is in the modifier panel) your computer will slow down because of a high polygon count. A lower polygon count make your computer move faster. We found this put the hard way when a scene showed up with about 30 million polygons.
You can check polygons by going into the utilities toolbar (one of the six tab menus on the left) and clicking more. You'll then find polygon counter. This has always been a big help to me.
hope that helps a little.
soukupd_gv@hotmail.com
Team 74 Alumni
2003 Great Lakes, Midwest, and West Michigan Regional Animation Award Winner
Unread 20-03-2003, 22:37
#0617 ((not named))
thx for the "poly watchers" tip.
My comp's stats are
600 Mhz Celeron
192 Meg SD Ram
Voodoo 5 graphics card (64 meg)
15 gig HD
Using Max 4
-Psy Guy-
Unread 20-03-2003, 22:40
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
If you need any help, you can send us a line at Tucker.
Unread 21-03-2003, 07:50
Soukup's Avatar
Animation Guru
AKA: David Soukup
ah ha...that's why its lagging.
If I am correct I think that you are barely making it over that reguirements for max 4. If you have some money upgrade the ram and processor, and the video card as welll, (all though that won't make a real difference in animation) The reason you are getting so much lag is that why your models are pretty normal, your computer can't handle it. If you were to upgrade to 512 ddr, you wouldn't have any problem.
Just for you to compare
one computer had
384 mb sd ram
300 mhz
4 gb hard drive (2 scuzzis)
worked great for early modeling but after about 5000 polygons, we had major lag
My computer had
512 ddr dram
2x dual athlon 2000 mp's (1.7 ghz)
ge force 4 ti4200 video card
40 gb hard drive
I was able to move without lagging through scenes of 2 million polygons, with no problems. Upgrading your computer is your first step, and you'll be very happy with your investment.
Team 74 Alumni
Unread 31-03-2003, 00:24
Bmud Bmud is offline
#0435 (Robodogs)
Bmud is an unknown quantity at this point
Send a message via AIM to Bmud Send a message via Yahoo to Bmud
Jeez.. a lot of help telling psy guy his pc is too slow. =P
Try this: Go on and model your people one at a time. If it's your cup of tea, model each one in a seperate *.max file, and then import all of them into a scene.
While working on each model, it helps to hide things so they use up less ram. use the [view] tab on the right side. Try some of the options under [Hide].
Viewport settings can be changed for optimal .. viewing too. Right-click on a viewport's name (ie "Right" or "Perspective") and select wireframe to speed things up. If wireframe is too slow when playing back animation, try "bounding box" which encapsulates all objects in a box while hiding its contents. This mode is very fast, and still suprisingly tangible.
After all the modeling is done or if you would like to see some structure instead of boxes all the time use an OPTIMIZE modifier. This will virtually remove polygons from the model. This will also make draft renders go faster. Once you're ready for a final draft dont remove optimize! righ-click on the modifier and choose 'turn off in render' so you will get all of your original model's polys in the render and NOT in your viewport.
These are all very good tips imo. And now that the prep work is done, I highly reccomend you look over Joan of Arc which has to be the greatest character modeling tutorial ever written.
Good luck!!
If you'd like any more help, consult any one of us participating in G-3D. You can easily find us by looking for JabX's threads. There's a great logo competition going on right now. Submissions gotta be in by friday!
Unread 22-04-2003, 00:18
Salik Syed Salik Syed is offline
FRC #0701 (RoboVikes)
Salik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud ofSalik Syed has much to be proud of
Send a message via AIM to Salik Syed
his computer is pretty slow for any character animation, u need at least a pentium 2 or 3 , we have a dual xeon 1.7 w/ 1 gig ram and 128 nvidia quattro and even that get's slow at some tasks !
(only more than 40k poly chars.) but i suggest if u use meshsmooth check rendering and put iterations 2 4 or whaever then for view port put 0, this will speed other than that optimize ur models etc.. if u have the money search for "rational reducer" i don't have the mo ney so ... i just use a faster machine (trust me it's cheaper!)
A joke they called Regional Animation Competitions Lev 3D Animation and Competition 50 18-03-2003 21:18
award for regionals Tyler Olds 3D Animation and Competition 13 20-12-2002 18:16
288, the Robodawg's animation Don 3D Animation and Competition 4 08-04-2002 20:56
How to develop your animation idea and keep your sanity too! Robby O 3D Animation and Competition 0 25-01-2002 01:25
the animation teams of F.I.R.S.T. animation teams are under appreiciated! Zeinin 3D Animation and Competition 11 14-01-2002 10:36
