Go to Post It's a shame that this is likely the year that sacred ground will be touched by that unworthy drive :rolleyes: - AdamHeard [more]
Unread 21-01-2002, 13:46
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
Skyway wheels w/o bearings
Has anyone had any luck fixing the skyway wheels to a driven shaft? I assume that the bearings on the wheels will have to go, but I need to know how to do this without ruining the wheels. I'd also like to know what the ID of the wheels is without the bearings, so I can tell our machinist what size shaft we need. Thanks.
Zan Hecht
Scorekeeper: '05 Championship DaVinci Field/'10 WPI Regional
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Unread 21-01-2002, 23:44
iscrc2 iscrc2 is offline
#0568 (Nerds of the North)
iscrc2 is an unknown quantity at this point
When I ordered wheels from skyway they sent a nice 8 page fax to order from that has some specs on wheels. It looks like the I.D. for our hubs is .906 (with the bearings removed).
But I don't see how you would affix the "bear" hub to a driven axle.
Skyway (from the fax) looks like they make others hubs that have keyways. I don't know if you can swap hubs but you might be able to purchase other hub/wheels that would attach by design.
Unread 22-01-2002, 00:53
Jordan A.'s Avatar
Jordan A. Jordan A. is offline
#0781 (Kinetic Knights)
Jordan A. is an unknown quantity at this point
Send a message via ICQ to Jordan A.
we ordered today and are getting keyed hubs...
Unread 22-01-2002, 00:56
joe_balint joe_balint is offline
FRC #3324 (Metrobots)
Rookie Year: 1997
joe_balint is an unknown quantity at this point
What we do is machine out the hub because of the draft (i.e. taper) inside the hub and then we insert a custom machined hub into the wheel, typically the ID of that new hub is 3/4" then we use a trantorque to couple the wheel to a shaft. It's pretty stright forward, one of the tricks is to try and make the new custom hub as lightweight as possible. -Joe
Engineer
joe.balint@gmail.com
http://www.OhioValleyTesting.com/
"The greatest enemy of a good plan is the dream of a perfect plan." -Clausewitz 1832
Unread 22-01-2002, 01:25
Greg Needel's Avatar Unsung FIRST Hero
Greg Needel Greg Needel is offline
REVving up for a new season
FRC #2848 (All-sparks)
Greg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond reputeGreg Needel has a reputation beyond repute
what we did
ok here is what we did. we ordered the 8.5 by 2 wheels. we replaced the bolts that hold the hub together with longer ones longer by 2.5 inches. then we made a custom plate the fit on those 5 bolts that then attached to our sprocket(secret connection) if you can figure out your own way of connecting the plate to sprocket then the wheel is driven by the hub and not the axel which also means that it can be a dead axel. This is a good thing so you don't have to worry about the critical alinment of the pillow block (you don't need them) your axel can be hard mounted to your frame
greg
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
has anyone ordered the wheelchair wheels outside of skyway? archiver 2001 0 23-06-2002 23:17
In need of 8" skyway wheels archiver 2001 6 23-06-2002 22:58
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
Are bolts to hold wheels on, and bearings, considered "fasteners"? kmcclary Off-Season Events 3 22-10-2001 23:35
