Go to Post Some of the best team captains I've seen have been from rookie teams. - Conor Ryan [more]
Unread 23-03-2003, 17:00
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
power transmission NOT using gears/chains?
I was toying with possible gearbox/transmission ideas as a start for next year, and I was wondering if polyurethane or however that is spelled rollers would work to transmitt power like a gear.
specifically, I was thinking about MrB's white pages gear ratio thing that had an idea for a CVT at the bottom, and was wondering is high traction rollers would work.
overview: mrB had two cones side by side, one with the base at the top of the drawing, on with the base at the bottom, so there was a constant distance between them. And in between them was a gear/roller that could move in the space between them. At one end it was close to the base on one and the narrow part of the other, at the other end it was reversed . . so as you slide it back and forth the gear ratio changes. Gears could not work for this design, at least not without very very complicated tooth patters, and maybe not even then. But what if you used high traction rollers? It would even act as a clutch of sorts, if you could vary the tension.
so, how would I get good sticky stuff to put around cones? Also, the roller in the middle may be hard to move, so maybe an omni wheel type thing would be best. or just really powerful actuator to move it.
MrB's spreadsheet is here.
Well, really what I want is polyurethane/other sticky stuff suppliers to scout.
end.
Types of Drives? indieFan Technical Discussion 50 20-10-2003 12:27
power to the pits Ken Leung Off-Season Events 12 11-05-2003 22:48
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
