Go to Post oh, the prom! I thought you were missing a PROM (Programable Read Only Memory) ...you had me worried for a minute, I dont know if IFI has any spare PROMs. - KenWittlief [more]
Unread 23-03-2003, 18:52
J2Kraatz's Avatar
J2Kraatz J2Kraatz is offline
AKA: J2
#1037 (S.C.R.E.A.M Team)
Team Role: Student
J2Kraatz is an unknown quantity at this point
Send a message via AIM to J2Kraatz
Mistakes
How many people realized that they built the kind of robot this year. I know I am not the only one. Where did you screw up we built a stacker and saw that bulldozers won the Great Lakes Regional basically.
Jason "J2" Kraatz
Reminding you to think outside the bot.
Unread 23-03-2003, 18:58
katie86's Avatar
katie86 katie86 is offline
#0086 (team resistance)
katie86 is an unknown quantity at this point
Send a message via AIM to katie86
We built a bulldozer, but it had stacking capabilities...
...that we never used except for one time in practice.
vive la resistance
2003 UCF Finalists
Thanks 79 and 233
Unread 23-03-2003, 19:10
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
We too built a stacker. We think it will work well, if we can get our drove system working. If it is working. then we can get it working.
Our main mistake was putting too much effort into that and not more on the drive system. We are still overheating and having troubles going up the ramp.
At a team meeting today we said (if I am not mistaken), that our drive system works, then our next priority would be our stacker.
Unfortunately, since we need to go under the bar with our current drive system (since the castors on our robot do not work well on the ramp, we are stuck in our underbar mode. Our robot can make it up the ramp if we are dead straight, like we did in match 1 in Phoenix, but if we aren't dead strait, breakers start popping and the castors turn making it hard to make it up the ramp.
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 23-03-2003, 19:31
Sophey Chan's Avatar
Sophey Chan Sophey Chan is offline
#0945 (Element 945)
Sophey Chan will become famous soon enough
Send a message via AIM to Sophey Chan
I wouldn't say we screwed up in our design. We built a stacker, which is great, cause we can do 4 easily usually, cause msot get knocked, but ours had enough force to be a blocker, and king of the hill, and we have a working auto with wings, which with our foorce is schweet in collisions in auto. Oak Ridge's is about the same. Most people don't liek stacking, but in some competitions, it is the best thing.
Unread 23-03-2003, 19:39
jadien's Avatar
jadien jadien is offline
#0694 (StuyPulse)
jadien is an unknown quantity at this point
Send a message via AIM to jadien
694's robot, Lola, was designed to be a stacker, stack-stealer, and stack-protector, but we wound up with a sweet bulldozer. Its arm and grabber are excellent for knocking down multiple hill stacks, and its drive system made it probably the fastest robot at the NYC regionals while still in a low enough gear with enough traction to go toe-to-toe with devoted bulldozers like 19's and 395's.
Unread 23-03-2003, 19:45
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Haveing built a stacker wasn't a mistake.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 23-03-2003, 19:52
kristen's Avatar
kristen kristen is offline
PI loves you!
#0639 (Code Red)
Team Role: Human Player
kristen will become famous soon enough
Send a message via AIM to kristen
It's a mistake if you don't use it sucessfully.
Unread 23-03-2003, 20:02
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Yes, we did not succeed in stacking many times, Kristen, but at least we could.
The reason it wasn't a mistake was because we could push any robot... I just watched the video of Chesapeake again (I got it from Rog but still need to digitize it) and saw that there were many box type robots designed to push bins/knock over stacks, but we had more torque than them. So we became a pusher, but the ability to also stack was a useful other feature.
Btw, talking about box type robots and extra features, could someone from 384 explain what that T-shaped bar on Sparky was supposed to do? The only useful purpose I remember was being cocky and waving it up and down in Chesapeake
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 23-03-2003, 20:03
Matt Reiland's Avatar
Matt Reiland Matt Reiland is offline
'The' drive behind the drive
None #0226 (TEC CReW Hammerheads)
Rookie Year: 1999
Matt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond reputeMatt Reiland has a reputation beyond repute
We built a stacker bucause it is important, but we only let the stacking team have 24lbs, the rest was left for the tank drivetrain with air-shifter all down low so we wouldn't fall over and armor all around.
It seemed almost all of the stackers were somewhat top heavy and only a few (67) realized it and made self righting mechanisms.
Unread 23-03-2003, 20:23
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer &amp; Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
not to throw the subject off a lil. but only 3 weeks of competitions have gone by and from what i see u all built robots with high scoring capabilities. both stacking and dead recknoning / line tracking robots
no one team has screwed up at all. stacking machines at the NYC regional looked cool. i didn't see much stacking though. if anything i saw a lot of bulldozer machines espicially a look alike bulldozer from i think it was 1230 the leonics with their robot leo. hope i got the team name number and robot name right !!
if its one thing i saw teams screwing up on; it was their ability to drive up the ramp. many of the teams got stuck at the bottom / middle of the ramp. whether it was caused by a slow robots drivetrain or improper material used as drive material or they just over heated. i expected many of the teams to do belt drive this year but i see alot of wheeld robots instead.
Basically though no team has screwed up at all with their robots. and to add this competition this year calls on both stacking and bulldozing capabilities to make a high scoring match rather then previous years where teams relied on 1 type of robot to make a high scoring match
2001 - required a ball grabber machine that could grab and balance 2 goals with the remaining 3 robots in the end zone
2002 - ball grabber robot that can control 2 goals
2003 - stacker or bull dozer robots that can move boxes.
this is just my opinion!!
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 23-03-2003, 20:27
T967's Avatar
T967 T967 is offline
5 IA teams, WHOs w/me?
AKA: Seth F.
Team Role: Student
T967 is on a distinguished road
Send a message via AIM to T967
I whole heartedly agree!
We won so many matches because of this it's not even funny. Some teams might want to concider using the gyro to help control your bot on the ramp. From a driver's point of view it works great.
Old dude wondering if he can really get back into this crazy thing called FIRST.
Unread 23-03-2003, 20:47
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Rookie Year: 1998
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
KOTH
Yea, we thought that stacking wouldnt be a huge factor in the game, however it is, but, stacks are easily knocked down. SO, we went with a king of the hill bot. Works great, cept for a few autonomous probs, but ive seen a lot of stackers "converting" at regionals.
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Fantasy Basketball! EddieMcD Chit-Chat 11 03-11-2003 18:05
New Submission Format for Chairman's Award David Kelso Chairman's Award 110 13-02-2003 14:28
3-d studio max archiver 2001 21 23-06-2002 23:28
Blue Prints archiver 2001 3 23-06-2002 22:33
Student Members vs. Adult Members Summmergrl2298 General Forum 12 16-01-2002 22:25
