Go to Post Another lesson is don't post on Chief Delphi disappointed, stop and evaluate first. Emotions suck sometimes. :-) - sircedric4 [more]
Unread 28-03-2003, 22:54
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
Obscure PBASIC for RoboEmu
Alright all you PBASIC Gods out there: here's a few stumpers for you! I'm in the middle of re-doing the expression evaluator (read: deleting and starting over) for RoboEmu 2.0 and need some help with a few of the more archaic, odd, and downright nutty things you can do with PBASIC.
Without further ado, here they are:
1. What do equalities actually evaluate to? I ask because things such as "if ((5>3)=3)=1<2 ..." are actually valid syntax. However, figuring out the value of this depends on what things like (5<3) actually evaluate to. Is it 1? Undefined? Variable based on the situation? Also, are these left-to-right or right-to-left?
2. What does the keyword AND/OR/XOR actually do? Similar to the above example, "if 3 AND 4 ..." is valid. I assume PBASIC will evaluate this to true as both 3 and 4 are non-zero, but can anyone confirm this?
3. How long can labels, variables, etc be? I believe it's 32 characters, but can anyone confirm/deny?
4. Not really a question, but more of a confirmation thing. Here's the order of operations I've come up with. Is this right?
top: AND, OR, XOR
next: =, <>, etc
next: ~, SIN, etc
last: +, -, etc
5. Anyone have any other obscure features you'd like to make sure RoboEmu supports?
Thanks in advance for all your help!
--Rob
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
PBASIC ARCTAN function Greg Ross Programming 14 11-05-2003 12:28
Need to learn PBASIC...Where Should I Go? IMDWalrus Programming 5 29-04-2003 16:43
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
RoboEmu 1.09 (supports PBASIC 2.5) rbayer Programming 22 21-01-2003 17:22
RoboEmu v.1a (another PBASIC emulator) rbayer Programming 0 07-07-2002 00:45
