Go to Post my theory on the matter was always something along the lines of "Oh, we're all girls? What an odd thing for you to notice." - karinka13 [more]
Unread 22-01-2002, 01:07
Robb Gerber's Avatar
Robb Gerber Robb Gerber is offline
#1620 (CSIS)
Robb Gerber is an unknown quantity at this point
Chip Motor Gear
What type of metal is that 44T 36DP Gear we got?
Unread 22-01-2002, 08:52
Joe Johnson Joe Johnson is online now
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
My Sources Say...
The metal of the gear that mates with the Chiaphua gear is
"FX-2008-90HT copper infiltrated steel heat treated to Ra 68"
A friend looked up the spec. It has a Min Ultimate of 90,000psi.
Hope this helps.
Joe J.
Unread 22-01-2002, 10:43
Unsung FIRST Hero
Ed Sparks Ed Sparks is online now
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Rookie Year: 1996
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Question Pressure Angle ?
A lot has been said on other posts about the specs for this gear but I cannot find the pressure angle mentioned anywhere for the smaller 32 pitch portion. Past descriptions describe it as a "standard" 32 P gear. Would that be the 20 degree or the 14.5 degree standard. It visually appears to me to be closer to the 14.5 degree involute.
Does anyone know for sure?
Ed Sparks
MECH TECH FRC-3959
Unread 22-01-2002, 11:07
Keithicus Keithicus is offline
#0920 (Lancers)
Keithicus is an unknown quantity at this point
Ed,
From Update #2:
"The smaller (16 teeth) gear of the cluster pair is a standard 20-degree pressure angle, 32 diametral pitch configuration, and may be mated with other 32 pitch standard gears."
-Keith
Unread 22-01-2002, 17:21
Jordan A.'s Avatar
Jordan A. Jordan A. is offline
#0781 (Kinetic Knights)
Jordan A. is an unknown quantity at this point
Send a message via ICQ to Jordan A.
while were on the subject my mentors want me to verify that the gear can be run on a shaft without some sort of bearings attached to it.
Is this right? I think I remember hearing someone mention it has brass in it? Or some kind of self lubrication, or alternative.
Not sure really, I dont know much about this.
Unread 22-01-2002, 19:56
#1620 (CSIS)
Thanks Joe...
and To Jordan,
I'd highly recommend you mount the gear on a shaft that rides on bearings and lubricate the gears
5000 rpm can produce alot of shrapnel
You don't want to picking your grears off the floor
L8TR
What RAM chip has... MarkF Chit-Chat 4 24-03-2003 20:39
Help with the gyro chip Team852 Electrical 1 10-01-2003 22:31
Auxilliary Basic Stamp Chip Kai Zhao Technical Discussion 9 07-01-2003 21:21
chip motors next year? JamesJones Motors 3 15-05-2002 22:38
Have YOU used the gyro chip? FotoPlasma Technical Discussion 10 31-01-2002 13:26
