Go to Post When you start new threads, keep in mind that ChiefDelphi has about 14.6 million subforums about nearly everything you can imagine in the world of FIRST. You have to be in the forum you'd like for your thread to appear in when you choose to start a new topic. - Madison [more]
Unread 22-01-2002, 09:49
Tim Skloss's Avatar
Tim Skloss Tim Skloss is offline
Dr. Skloss
FRC #0930
Team Role: Parent
Rookie Year: 2000
Tim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the roughTim Skloss is a jewel in the rough
Gray box limitations
What exactly are the limitations on using the $100 worth of "electrical components" from DigiKey?
Do ALL of the components need to be in the gray box?
Do ALL of the components need to be on the circuit board?
We want to measure shaft speed with a hall-effect sensor. We want to put the sensor near the shaft, but if the components must be in the box (or on the CB) then that presents a problem. One way around this is to use strong magnets on a nearby shaft, sproket or gear that can trigger the sensors in the box. But this approach requires all measured shafts to be in close proximity to the gray box.
Has anyone tested this ruling?
On another note, I consider CB fabrication and any other parts from DigiKey that are explicitly listed in the Additional Parts List as falling outside the $100 limit. Only non-listed components from DigiKey should fall under the $100 limit.
box orientation Lance General Forum 1 13-02-2003 10:12
box grabbing matt111 3D Animation and Competition 3 27-01-2003 23:08
project box archiver 2000 2 23-06-2002 23:01
Modular Control box assembly Andrew Wyatt Technical Discussion 4 29-11-2001 15:44
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
