Go to Post So next time you speculate, label it as such and not as established fact. Please. Bad information is worse than no information. - DonRotolo [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 01-04-2003, 19:13
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
Parsing the USFIRST Champ list
Hey all...
Here is some php code that will parse the usfirst team list for the champ event for you. You can change the echo's to assign the fields to an array which you could insert into your db. If you have any questions, feel free to ask me.
PHP Code:
<?php
//Team Parser for The 2003 FIRST Champ. Event
//Designed by: Andrew Schenk (email: [email]webmaster@feds201.com[/email])
//Code tested on PHP 4.3.1 - (should work on any 4+ version & mabey 3 depending on some functions)
//Known Bugs:
//The current source code for the team website is not correct.  It is missing the "" around the url.
//If first decides to correct this error do the following to the code:
--find--
echo substr($var, (strpos($var, 'href=')+5), (strpos($var, '>') - strpos($var, 'href=')-5)).'<br />';
--replace with--
echo substr($var, (strpos($var, 'href="')+6), (strpos($var, '">') - strpos($var, 'href="')-6)).'<br />';
//I'm 99% sure that would correct the code, but not sure exactly how they would change it so... who knows?
//to actually use the code, replace the echo statements with an array var and then you could dump that array into your db
//hehe... actually going to include a few comments...
//--get source code from usfirst--//
$source '';
$source_pointer fopen('http://www.usfirst.org/frc/map/FMPro?-db=team%20events.fp5&-lay=web&-format=team_list.htm&event=CMP&event%20year=2003&status=signed%20up&-sortfield=team%20id&-max=all&-find'"r");
if (
$source_pointer === false )
    die(
'Could not open url');
while ( !
feof($source_pointer) )
$source .= fread($source_pointer1024);
fclose($source_pointer);
$x 0//$x is going to be the var to hold our string offset in all the strpos() functions
while ( strpos($source'<TR BGCOLOR="#FFFFFF">'$x) > $x )
    echo
'<hr>';
$x strpos($source'<TR BGCOLOR="#FFFFFF">'$x) + 22//find the start of a new record (<tr>) and then offset the pointer to the end of it
while ( strpos($source'</TR>'$x) > strpos($source'<TD class="news">'$x) && strpos($source'<TD class="news">'$x) > $x )
$x strpos($source'<TD class="news">'$x) + 17//find the start of a new field and offset the pointer to the end
$var trim(substr($source$x, (strpos($source'</TD>'$x) - $x))); //assign the field to the var
if ( strpos($var'<A') !== false //decide if the var has a link in it
            echo
substr($var, (strpos($var'href=')+5), (strpos($var'>') - strpos($var'href=')-5)).'<br />'//get url from link
$var strip_tags($var); //return the team name
echo $var;
        } else {
            echo
$var.'<br />'//return a var without a link
//--the end--//
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
[IMG] code is Off
POLL: How do you feel about Nationals being in Atlanta?? DanLevin247 Championship Event 63 21-07-2003 19:34
Parsing usfirst Match Data Jack Scouting 0 08-03-2003 02:00
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
Team list & Events archiver 2000 2 23-06-2002 22:39
Suggested list of things to bring to the regionals Andrew Wyatt Technical Discussion 1 06-03-2002 14:41
