Go to Post I trust in Martus. - Petey [more]
Unread 02-04-2003, 12:36
Gary Bonner Gary Bonner is offline
FRC #3974
Rookie Year: 2000
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Drill Motor Transmission
We had a few problems with our drill transmissions at the Philly regional, which was the first time we gave them a real workout. Fortunately, most were on Thursday, but one happened during the semifinals leaving us unable to steer.
The first problem was with the shifter clips popping out and was easily remedied. The second problem, I think, was caused by the clutch housing separating or shifting slightly away from the gearbox housing and causing the clutch to disengage. At the time, in the rush of the competition, we merely swapped the transmissions for new ones. We figured the little tabs that hold the housings together had broken off. After looking over some of the parts back home, I’m now wondering if the clutch housing just rotated, since it provides all the torque keeping the last ring gear from rotating. (I can’t picture right now whether the mounting hardware grips the clutch housing; we’re using the FIRST provided mounting assembly) If this is the case, then the problem should only occur when running in low (which we do), since the shift ring prevents the clutch housing from rotating when in high.
I was wondering how many teams have had this problem, and if you were running in high.
Thanks
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
