Go to Post From past experience members of our team insist on never trusting gravity. - Vash [more]
Unread 04-04-2003, 23:54
srjjs's Avatar
srjjs srjjs is offline
Slightly Rehabilitated
AKA: Larry Wang
#0840 (Aragon Robotics Team)
srjjs will become famous soon enough
Send a message via AIM to srjjs
positioning system
840 would like to make an inertial positioning system. Does anyone from the teams that have made one have any tips/advice?
SVR Imagery Award
SVR Semifinalists with 473 and 687
RIP Andrew Dang
3/22/2004
Unread 05-04-2003, 00:59
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Re: positioning system
I assume you're talking about next year or something to work on in the off season, right?
Your question is pretty broad - do you have more specific questions? You'll probably need an external microprocessor on a custom circuit board. Have you thought about which one you want to use? Have you checked out sensors that you'd like to use?
Unread 05-04-2003, 01:20
srjjs's Avatar
AKA: Larry Wang
Yes, this is something for our team to work on in the off season, as we are not going to nationals.
I am just looking for some general stuff, like how much it will cost, how long it will take, what kind of stuff to use, etc.
A step-by-step guide would take away most of the challenge.
SVR Imagery Award
RIP Andrew Dang
3/22/2004
Unread 05-04-2003, 12:42
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
ahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond reputeahecht has a reputation beyond repute
Send a message via ICQ to ahecht Send a message via AIM to ahecht Send a message via Yahoo to ahecht
The hard part with an INS is the actual programming. Building 190's INS didn't take very long, but getting it to communicate with the RC, getting it calibrated, filtering out noise, and general troubleshooting has been a major challenge. Our programming team spent the entire build season working on it, and has been working with a second INS and the EduRobot since the build season ended, and as I type this, they are probably busy in the pits at Seattle still perfecting it.
The other thing you need to know is that the gyros in the kit are not fast enough to work in a real world situation (I think they only track up to 110 degrees/sec), so we had to buy some 300 degree/sec gyros out of our additional electronics budget. Also, noise control is a big issue. With the noise we are getting, in a worst case scenerio, our INS can think it has reached escape velocity in 15 seconds while the robot is standing still (although it usually averages out to provide reasonable results during our autonoous mode, when we really need it). Don't forget that you need to do a double integral to determine position, so any noise in acceleration or yaw rate would be cubed.
I'd encourage you to go ahead and try it. It is always to to see FIRST teams pushing the envelope.
Zan Hecht
Scorekeeper: '05 Championship DaVinci Field/'10 WPI Regional
Co-Founder: WPI-EBOT Educational Robotics Program
Alumnus: WPI/Mass Academy Team #190
Alumnus (and founder): Oakwood Robotics Team #992
"Life is an odd numbered problem the answer isn't in the back of the book." — Anonymous WPI Student
Unread 05-04-2003, 14:08
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
what are you using for the gyro?
What did you use instead of the gyro in the kit? I bought the evaluation version of the Analog Devices ADXRS150 gyro. Its mounted on a very small PCB that is the same size as a regular 20 pin DIP IC. The part number is ADXRS150EB. The standard max velocity is 150 degrees per second, but the rate can be increased by adding a resistor up to 300 degrees per second. It also includes an onboard low-pass filter for some noise rejection. I was just wondering if anyone has used it.
Unread 05-04-2003, 14:49
srjjs's Avatar
AKA: Larry Wang
And all these components fit under the electronics cost limit?
SVR Imagery Award
RIP Andrew Dang
3/22/2004
Need a FIRST Robotics control system kershawrobotics General Forum 3 07-07-2003 09:49
Scoring system for 2004? DougHogg General Forum 11 16-04-2003 20:57
control system worth more than $500 archiver 2001 8 24-06-2002 02:00
New Innovation FIRST control system and the dashboard archiver 2000 0 23-06-2002 22:15
Ok, how much is the control system worth? archiver 2001 6 23-06-2002 22:05
