Compass/direction sensor
We would like to get our hand on two compasses that will plug into the robot controller and the operator interface. We don't really want to use the angular motion sensor, all we want to know is the anlge between whatever way the OI is facing and whatever way the robot is facing. I'm gonna go hit up google, but if anyone knows a good supplier offhand please respond.
thanks. edit: I found this and this but I was kinda hoping to find one ready to plug into the controller and return a number between 0-360 or 720 or whatever. HEY! word! look at this baby!linky! Last edited by Frank(Aflak) : 05-04-2003 at 15:02. |
Note that you're not allowed to hook custom electronics up to the OI...
Also, our team looked extensively at several magnetometers and found that they are essentially worthless when placed inside the robot. |
but could it be considered an analog input? sort of like a pot, if it returns the correct voltage?
plus, would one of those crazy "R2 Logic Ladders" (or whatever it is when you make an analog input into many digital ones) be illegal then as well? |
Ian,
As Dave said above we did some rather extensive research into direction finding and compass usage. Besides the fact that they are somewhat expensive, they cannot distinguish the earth's magnetic field when placed within the robot frame with all the DC(magnetic) motors and various metals in the construction. There is also so many variables when used inside buildings due to electric fields and metals in the roof, walls and floors. Although they look very good on the surface they became to difficult to implement. Sorry. If you are intending on using a feedback system from the OI to the robot, teams have been using the gyro for years to do that so there is a lot of info around. Remember that if the sensors are initialized correctly, they should track fairly well over a two minute match. |
Wrap the wires around each other. The magnetic fields will actually cancel each other out. As for the motors putting capacitors across them should help out on interference. As for the price I have found a company that makes fairly cheap compass sensors. Yeah this is not for first but another robotics project of mine.Last edited by Adam Y. : 05-04-2003 at 18:16. |
Look Here
We did something with a magnetic sensor last year (2002) for our customized I.D.A.N. (Intelligent Detection, Analysis and Navigation) system. Read my post there and if you want more info please let me know and I will see what I can do. |
#11
We did come across several compass chips that had reset lines to pulse the chip and surrounding area to kill the local fields and try to take a reading. That pulse was in the two amp range and required some external circuitry that was expensive and weighty. After weeks of walking down the compass path, we abandoned the research in lieu of a far simpler approach, the gyro. Yes it has it's faults but the accumulated errors over a 15 second period are small. If you are still researching, check out magnetic shielding products. They are usually high nickel and laminated steel products. You may be able to put a shield between the robot and the compass. There must be a way to do it because my Dodge van has a compass that works fairly well although it only gives eight directions. |
| Reflective tape sensor? | scitobor 617 | Electrical | 2 | 19-11-2003 08:51 |
| sensor doesn't work | PBoss | Programming | 7 | 29-01-2003 18:39 |
| Sensor or no Sensor For Autonomous mode | Kyle1010 | Programming | 14 | 22-01-2003 13:10 |
| How do you connect optical sensor? | archiver | 2001 | 1 | 23-06-2002 23:05 |
| Optical range sensor | Ben Mitchell | Technical Discussion | 9 | 12-01-2002 00:11 |
