Go to Post Just because you can doesn't mean you should. - pfreivald [more]
Unread 06-04-2003, 16:25
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Robot Controller Reset Problems.
On our 4WD drive robot (two drill motors and two Atwoods)we had 8 good matches with no problems, then on our last match the clips fell out of one of our drill motor transmissions, so we replaced both the drill motor and transmission. Then we noticed the voltage readout on our OI would drop to around 7v and reset our RC, when taking our robot from full reverse to full forward or full left to full right. Then we tried changing the 40 amp breakers around and the problem went away for the next match. Then it came back later in another match. Does anyone have suggestions to narrow down our problem?
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Visibility of Robot Controller and Reset Button Tracy Rules/Strategy 1 17-02-2003 07:36
Robot reset on OI doesn't work Carl Owenby General Forum 1 07-02-2003 07:23
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
