Go to Post And remember, it's the fall semester. So FIRST isn't an excuse for a failing grade (not that it's ever an excuse)! - Billfred [more]
Unread 23-01-2002, 00:31
punarhero's Avatar
punarhero punarhero is offline
#0696 (Clark Magnet Robotics)
punarhero is an unknown quantity at this point
Send a message via AIM to punarhero Send a message via Yahoo to punarhero
PBASIC problem
I started programming today. Two motors work on pin 1 and 2 off of port 1 and 2 joysticks on the y-axis. So, each joystick is running one motor on its y-axis.
What I want to do is have a drive train with 4 motors. How can I made 4 motors run on only y-axis of two joysticks, i.e. two motors on y-axis of each joystick
Thanx
Punar
Unread 23-01-2002, 00:55
Unsung FIRST Hero
Nate Smith Nate Smith is offline
FRC Key Volunteer Trainer
AKA: CrazyNate
Rookie Year: 1998
Nate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to behold
Send a message via AIM to Nate Smith Send a message via Yahoo to Nate Smith
Basically, just set a speed controller on each motor, and send the same value to both of the left motors, and the same signal to both of the right motors
Nate Smith
nsmith@smythsoft.com
12 seasons, 4 teams, and more time logged behind the scorekeeper's table than I care to remember...
returning for 2011? only time will tell...
Unread 23-01-2002, 00:56
Greg Ross's Avatar
Greg Ross Greg Ross is offline
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Rookie Year: 1998
Greg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond reputeGreg Ross has a reputation beyond repute
Send a message via AIM to Greg Ross Send a message via Yahoo to Greg Ross
All ya gots to do is...
Download the default program from the Innovation First site and edit it to output p1_y and p2_y to two more PWMs. So if you hook up your other two motors to PWM3 and PWM4, your serout command would be:
PHP Code:
Serout USERCPUOUTBAUD, [255,255,p1_y,relayA,p2_y,relayB,p1_y,p2_y,p1_x,p2_x,p3_x,p4_x,p1_wheel,p2_wheel,p3_wheel,p4_wheel,127,127,127,127
Greg Ross (The Grammar Curmudgeon formerly known as gwross)
S/W Engineer, Team 330, the Beach 'Bots
<--The Grammar Curmudgeon loves this cartoon.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!" Hunter S. Thompson
"Playing a practical joke means doing something mean and calling it funny." Me
Unread 23-01-2002, 07:16
Lloyd Burns Lloyd Burns is offline
FRC #1246 (Agincourt Robotics)
Rookie Year: 1997
Lloyd Burns is an unknown quantity at this point
Re: PBASIC problem
Thanx
Punar
Did you connect a motor to PWM # 5 ? This is the default program's output for the x axis of the Port 1 joystick, and quite helpful for turning, in one-stick "tank" steering (look into it on the Innov'n First Board).
Unread 23-01-2002, 17:39
Joseph F Joseph F is offline
#0506 (Steel Friars)
Joseph F is an unknown quantity at this point
Send a message via AIM to Joseph F
um. y-splitter. Hook up the left motors to independent victors, then attach the victors to a y-splitter and then put the other end to pwm1. do the same on the right with pwm2. its the simplest method.
One Team, One Bot, One Fleet of Ambulances!
Unread 24-01-2002, 09:16
Unsung FIRST Hero
AKA: CrazyNate
Rookie Year: 1998
If I remember correctly, splitting a signal to two speed controllers is pushing the limits of the power supplied on the PWM signal for the speed controller's optocoupler. Technically, it can be done, but personally, I'd say play it safe and give each speed controller to its own set of pins.
Nate Smith
Unread 24-01-2002, 16:46
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Rookie Year: 1996
Y's are okay I think...
I am pretty sure that a Y on a PWM cable is just fine.
Joe J.
Unread 16-02-2002, 23:13
GhettoTech GhettoTech is offline
#0300 (Ghetto Techs)
GhettoTech is an unknown quantity at this point
Send a message via AIM to GhettoTech
There are definantly several different ways to solve this problem.
Mechanically:
You could run a chain from one motor to drive two wheels on one side.
Electronically:
You could use the Y splitters from one PWM output to go to two different speed controllers (each controlling a different motor)
Softwar(ly?):
The "Serout" command at the end of the default code is what sends out the signals to all the electronics. You could simply connect each motor's speed controller to its own PWM output. (Let's suppose the motors on PWM 1 and PWM 2 are the two motors you want to run simultaneously from one joystick [plugged into port1], and PWM 3 & 4 from the other joystick [plugged into port 2])
You could change the output line from:
Serout USERCPU, OUTBAUD, [255,255,p1_y,relayA,p2_y,relayB,p3_y,p4_y,... (etc)
to:
Serout USERCPU, OUTBAUD, [255,255,p1_y,relayA,p1_y,relayB,p2_y,p2_y,...(etc)
Or
you could leave the output line alone and simply add, right before the Serout command:
p4_y = p2_y 'This makes PWM 4's output be controlled by Port 2's joystick (y-axis)
p3_y = p2_y 'This makes PWM 3's output be controlled by Port 2's joystick
p2_y = p1_y 'This makes PWM 2's output be controlled by Port 1's joystick
' Default program's comment code....
' blah blah blah
Serout USERCPU, OUTBAUD, [255,255,p1_y,relayA,p2_y,relayB,p3_y,p4_y,...(etc)
Whatever method is best for you, go for it
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
PBasic Select Problem powercat Programming 4 31-01-2003 11:01
The problem with scouting... archiver 2001 10 23-06-2002 23:49
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
