Go to Post Ironically, I think the best testament to the program [Dean Kamen] founded and his ideals wouldn't be if he won a Nobel Prize. It would be if you did. - Kevin Sevcik [more]
Unread 23-01-2002, 08:09
Leo M Leo M is offline
#0384 (Tucker Tigers)
Leo M is just really niceLeo M is just really niceLeo M is just really niceLeo M is just really niceLeo M is just really nice
Return of the Inverse Trig Functions
Our team is not planning on using the optical sensors to track the goals, but maybe some of you might want to experiment with them and would find a use for inverse sine and cosine functions that work with the Basic Stamp's idiosyncratic math processing abilities. The Stamp's sine (sin) and cosine (cos) functions take an argument (an angle) in 'binary radians' (brads) and output an integer result in the range -127 to +127. The brad is an angular measure arrived at by dividing a circle into 256 arcs, instead of the customary 360 degrees. A brad is 360/256 = 1.406 degrees.
Integer output of the functions is used because the Stamp knows nothing of numbers between 0 and 1. The normal 0 to 1 range (abs) of the sine and cosine is thus scaled up to 0 to 127.
If we restrict the discussion to angles between 0 and 90 degrees (0 to 64 brads), the sin and cos functions map integers in the range 0 to 64 into other integers in the range 0 to 127. Going the other way, the inverse sine and cosine functions should map integers in the range 0 to 127 into integers in the range 0 to 64.
In order to accomplish that, I fit quadratic curves to the integers obtained from the Stamp's sin and cos functions, such that the curves would take arguments in the range of 0 to 127, and return angles of 0 to 64. I used two curves for each inverse function, and pieced them together. I had to apply some 'end correction' to the inverse sine to get a closer agreement with the Stamp's sine values, but in general the inverse functions have relatively small errors. They aren't perfect; feel free to contact me for the details of how I arrived at them, if you would like to do some more work on the problem.
The inverse sine and cosine functions are presented below. They are valid for input in the range 0 to 127, and will output angles in brads in the range 0 to 64 (0 to 90 degrees). You will have to decide on what trig relationships will give you what you need if you want to work outside those ranges - but it is certainly possible. Also, you may wish to rename variables. The code needs to be all on one line - I have divided it for readability. Be very careful with the parentheses - think before changing them, or you may get some strange results. The quadratics are written in 'nested form' to keep intermediate values within the allowable range of the Stamp's word-length work space. So, don't be scared of the large integers inside the functions - everything works out.
arccosine:
arccos = ((1-(x/118))*(((-x-181)*x+48472)/769)) +
((x/118)*((((-3*x+707)*x-41331)/20)))
arcsine:
arcsin = ((1-(x/118))*(((x+181)*x+744)/769)) +
((x/118)*(((((3*x-707)*x+42611)/20))+((x-115)/3)))
Just one more note in this excessively long post. The (x/118) and (1 - x/118) use the Stamp's integer math to turn the two curves on and off at the right time. To the Stamp, 117/118 =0, and
127/118 = 1.
Good luck, and let me know if you use these.
Leo M.
