As an announcer I need " To see the Light" and the numbers. It's hard enough with all that's going on to remember every robot and number and team name and robot name and alliance and ............ Whoa.
You need to watch your robot which you see all the time and remember 1 alliance partner at a time. Even then I saw 2 alliance partners pushing each other around until they realized what they were doing. I saw robots that I would not have passed during inspection because their lights were not visable. FIRST needs to go back to having trained inspectors rather than team members. |
lights/flags for the crowd, drivers and mentors/human player(strategist) usually knew who was on what team.. i hope they did..
but yea the lights are awesome.. they really make the robots seem alive when they are out on the field.. maybe strobes or something but the lights should def. stay |
Back in high school I had a project for a tech class to protect an egg in a crash. The main rule was the egg had to be at least 2/3s exposed. Some students almost totally enclosed there egg. It survived the crash but they failed because they didn't fallow the rules. MY egg broke but since I fallowed the rules I got a B. It was much harder to design the restraint for an exposed egg. The same is true for choosing were to place the light on a bot.
I think FIRST should instill a clear rule that the light cover should be totally exposed. Teams may and are encouraged to surround the light in clear lexan or with a thin metal mesh to protect it from damage. Should the light be damaged during a round by collision or impact its a minor penalty. If a ref thinks that at anytime the light is not visable then the bot is assigned a minor penalty. The robot must meet wieght and size requirments. Wiring must be to code and the light should be part of a design requirement. Teams may complain that it impedes there design but so does a size limit. Its plain and simple, robots must be identified as to which team they are on. If by the placement of the light they are not allowing there bot to be identified they are breaking a rule plain and simple. |
The lights also have another purpose......after the season is over they become very useful.
for example our team was able to take our old robot to Burger King and we ended up placing it outside on the sidewalk with the light on, rotating, and with the red case over it. needless to say that at night time the cars on this very busy road, it is right before the expressway entrance/exit, slowed down to a crawl because they thought there was an accident....I ust love nosy human nature......anyways, while they were going extremely slow Aaron and I, aaron is a good fellow animator, ran over and tried to get them to honk there horns and come into the drive. we actually got several people to come in because they were curious...again love that human nature....we got some pretty good money that night. and we owe it all to the rotating red light that could be seen from all 4 sides. just a little story to show that those lights can be very useful....when used properly and has two crazy looking dancing people by it. |
How about LEDs? Ok, here's how it could work, you have a thin circular light case (could be like 1/4-1/2 tall because LEDs are little!) there are LEDs arranged around it in a circular pattern, with, and here's the key! BOTH (or all, if we end up with more than two colors next year) colors of LEDs are in the case, and using the IFI software, the colors are controlled by the field equipment (or a switch on the robot/in the program). This means you would never have to worry about switching light lenses, and it would most likely be much less prone to breaking, as it is smaller. This could then be mounted on top of the robot, meaning you can see everyones, and it's not blocked!
LEDs can also be WAY brighter than normal lights like we have now, I know my team had some of those wheel lights, and they were much brighter than the competition light. Also, you could do really cool strobing patterns if there were lots of LEDs. The link is to a really poorly made picture, I hope it gets the idea across. http://members.cox.net/johcagaorl/LEDlight.bmp |
I want to keep the light for nothing more then safety.
It really makes things clear: If the light is on the robot is likely to move in the near future, stay back. If it is off, it probably won't go anywhere. So simple even the freshman can figure it out. -Andy A. |
The light is important only IF it can be seen. That's a rule FIRST definately needs to enforce. Also, making sure the right color lens is on the robot should be enforced, or else it makes spectators beyond confused.
LED's would work, they are bright and lightweight. I'm all for it. |
#10
The problem I see with LEDs is there noone who makes a rotating LED light that I know of. FIRST probobly gets the lights dirt cheap so thats why they use them. Is it that much of a pain to change a piece of plastic. If you have trouble getting to your light most likely your one of the teams who buried it in your bot.
Its simple, put your light on the top of your bot, surround it with 1/8 inch lexan or the ramp mesh to protect it. I really hope FIRST cramps down on the teams who bury it next year. If having a the light in a legal position ruins a design then obviosly that design is faulty, just light a design that would make your bot 135lbs. |
#12
FIRST should more clearly mandate light visibility at the beginning of the season and then stick to it!
The challenge of the light placement should be looked at as just another "engineering opportunity -Jim- ------------------------------- I agree with Jim about them needing to enforce light visibility more. However I believe that it is stated quite clearly in the rules... and along with the numbers debate and some of the newer pnumatic changes... the teams just do not bother to read all of the rules and updates... and if they do, they just don't follow them because for heavens sake... it might make them have to do some engineering and change their design a bit. I mean how hard is it to have numbers on all four sides that are atleast 4" high? It's not people! But you still get the teams with the 2" numbers on two sides of their bot who grumble about not passing inspection yet. And then there were the few that just did not have numbers on them to start with... Durring inspector training at one of the regionals Team XXXX generously donated their bot so the head inspector could go over all of the things that we were looking for when we inspected the rest. It was a well build robot... and they only had three problems that we picked-up on. 1-some pointy edges 2-the number thing... but they were cutting out the new ones i believe and 3- you could not see the light from the front due to some stacked PVC... When the coach of Team XXXX came back... he assumed that we were going to pass him because he lent us his robot. We told him the three problems and he refused to change the light location. Eventually they just let TeamXXXX pass because there were a bunch of robots with the light issue. I saw robot XXXX competing later at another regional when i was going through the NASA-TV archives and they had not changed anything. Which pisses me off to no end, becuase the teams that do follow the rules and make their light visible have to modify their designs to include that... those that do not should not be allowed to compete... because they are not following the rules. The light is a good safety key... so you can tell when it is on... and i have had no problem with them when i was on the team... aside from them popping off ocasionally. (and sending current through the frame if not mounted correctly) This years light is lighter, and the top does not pop-off because it screws on. The only problem with that is if it cannot pop-off when put under pressure... it shatters... I saw many a broken light cover at the spare-parts table and i think if the plastic was a bit thicker like last years covers they bould not break so much. In final.... consider the rules when designing your robot... and build around them.... this is an engineering activity you know. |
#13
Personally, I thought many robots violated the light rules as originally stated. But because of all the whining, including much on this forum, the rule in practice was modified into something unrecognizable and practically unenforcable.
Much of that came from the attitude "Let's just do what we want, they'll change the rule to make it easier anyway". Based on past experience I don't blame people for having that attitude, but it still disgusts me, especially when I hear it from my own team (which I did, repeatedly). Assume at the outset that rules are rules and if you violate them, you may have to pay the price, even if it means you don't compete. That should go for name teams as well as rookies and vice versa. My suggestion for clear rules based on this year's light: The light shall be mounted in such a way that it is vertical in the robot's normal operating position. The light shall be EXPOSED for a minimum of 4 inches. Exposed means there is nothing between the surface of the light dome and the eye (or corrective lens in my case) of the observer. The light may be occluded by robot structure or protective cages, however the total width of the occlusion shall not be more than 50% of the light diameter at any angle. (so if the light diameter is 3" you can't have a structural element bigger than 1.5" or more than 6 1/4" rods for a protective cage) For purposes of this rule ANY material between the dome of the light and the observer is assumed to be OPAQUE. This includes materials that are normally transparent because the reflections that occur from field lighting on such materials can and do make it impossible to determine the light color under competition conditions. It must be possible for the team to change the light color in 15 seconds or less. If the there is any doubt about the ability to accomplish this, the team will be asked to demonstate to the inspectors in a timed test that this is indeed possible. The burden of proof for compliance will rest on the teams. That is, a light is assumed to be non-compliant unless the team can demonstrate that it's placement in fact complies with the above rules. Any comments? Last edited by ChrisH : 17-04-2003 at 17:31. |
#15
Looking at the person who suggested LED lights... I want to say you've got a really good idea!
For those of you unfamiliar with these, I found google'd some pictures that'll show you what they look like. The idea is you take some LEDs - preferably surface-mount LEDs to save space - onto a flexible strip of plastic or something similar. The wiring is done on the strip itself so all that teams have to do is plug them in on one end of the strip and they go. ![]() ![]() ![]() ![]() ADVANTAGES OF LED LIGHT STRIPS OVER ROTATING LIGHT: 1. Light weight - less weight you're required to put in, the more weight you CAN put in 2. Take up very little room - LED light strips can be mounted almost anywhere using just a little piece of velcro - you can have a strip mounted to the outside of each side of your robot - identification can't get much easier than that 3. No mechanical parts - no worrying or reports about the rotating motor breaking down 4. Very little current draw - more power can be directed to those massive 40amp breakers! 5. Neat strobe effects can be created using simple $1, $2 micros. The prospect of modding a strobe or night-rider-esque effect with microcontrollers would draw more programmers to doing something a bit more high-tech than writing measly code, attaching a wire to a laptop, and having it all magically work for you. 6. LED's don't burn out (unless you apply too much voltage to them) - although I've never really heard of teams having a problem with their lights burning out. DISADVANTAGES: 1. Blue is a relatively expensive LED color - utra-bright red led's cost about 10-15 cents each, ultra-bright blue led's cost about 2 dollars each. Can be solved by either buying in bulk, or making a different color alliance (like red vs green alliances). 2. If FIRST wants to make a 'light-equivalent' of leds (like was pictured above), it will probably have to be designed and built by them. Can be solved by instead of designing a new led product, just giving 4 strips of LED's in the kit and having teams mount one strip on each side with velcro or something similar. 3. If FIRST would choose the 4-strip solution, theres the problem of swapping colors/strips. Solutions: - - Use LED strips with plug-and-go molex-like connectors and velcro - - Mount both and wire a simple switch to control which turns on - - Or if you want the ability to change alliances in mid-match to add the element of confusion and surprise to the game, do solenoid-like wiring on the relay for the two mounted strips so you could change alliances at the flip of a switch at the OI ;-) Anyways, long story short, I think the advantages of using LED strips are really attractive and the disadvantages can be solved relatively easily. The biggest problem will be finding a supplier that can provide 4 (or 8, depending on the setup) x 1000 strips that will meet exactly what FIRST would require (brightness, size, connectors, etc) by next January. However, if they can find plastic mounts for motors designed to go into drills, I'm sure they'll be able to find a relatively simple LED product like this. Last edited by DanL : 17-04-2003 at 13:54. |
| light visibility | Erinn888 | General Forum | 30 | 17-02-2003 15:56 |
| What color light is better on your robot | Rob Colatutto | General Forum | 24 | 11-09-2002 20:33 |
| About the light that need to be seen from four side | archiver | 2000 | 3 | 23-06-2002 23:01 |
| Important info about light | Jay Lundy | Technical Discussion | 10 | 12-04-2002 11:37 |
| How many posters does it take to change a lightbulb? | Brandon Martus | Chit-Chat | 7 | 22-02-2002 19:48 |
