Go to Post I would argue that you are not overdosed if you don't know the correct name of this year's game - KarenH [more]
Unread 04-16-2003, 09:52 PM
18voltMilwauke 18voltMilwauke is offline
#0009 (Roboriders)
18voltMilwauke is an unknown quantity at this point
Send a message via AIM to 18voltMilwauke
Which team do u think used firsts gearboxes the best.
I was just wondering which team do u think used firsts gearboxe the best. isaw a lot of team modify and i just wanted ur opinion.
Unread 04-16-2003, 10:35 PM
/Pyro's Avatar
/Pyro /Pyro is offline
FRC #0292 (PantherTech)
Team Role: Mechanical
Rookie Year: 1999
/Pyro is an unknown quantity at this point
We opt-ed to use the FIRST gear boxes. (Team 292) We powered each side with 1 drill and 1 chalupa. (Chalupa = CIM) Ran that through the FIRST gearbox to a sprocket. From there we reduced it even further to the wheels. A lot of our power and traction came from our 8" pnuematic wheels.
I'm not saying we used them the best, but a lot of teams had a very hard time pushing us around ('cept for 25).
One of my favorite matches was during the finals in Chicago. Huskies had their legs planted in the grid, we came up and pushed them off the top. 45 gave us a slight nudge to help at the end, but we had them mostly off by that point.
Here is the link to the match on SOAP
http://www.soap108.com/2003/movies/il/il_fm1.asf
Nic Fouts, 2013 Team 1306
Mentor
Unread 04-17-2003, 10:08 AM
Halon Halon is offline
#0662 (Rocky Mountain Robotics)
Team Role: Driver
Halon is an unknown quantity at this point
Send a message via AIM to Halon
Team 662 had drills and CIMs for drive this year. Since the CIMs are about 4x faster than the drills/planetary gearboxes, we used two black 2:1 gearboxes per side to gear down the CIMs 4:1. We then hooked the drill motors/planetary gearboxes to the final output shaft of the gearboxes. We also had a sprocket on the output shaft and geared down the motors some more. We used these 8" pink pneumatic tires we found at Harbor Freight, and the whole setup proved to be great for both speed and power. We could push around anyone we needed to.
---Tyler Nicely---
Team 662
2004 Colorado Regional Winners
2003 Sacramento Regional Winners
2003 Sacramento Entrepreneurship Award Winners
Unread 04-17-2003, 10:41 AM
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Sounds inefficient but a good idea. How much space did it take up?
Unread 04-17-2003, 10:48 AM
Team Role: Driver
It might have been inefficient, but for a 2-minute match, who cares? We did run down our batteries pretty quickly, though. You can see a pic of our bot with the gearboxes installed here.
---Tyler Nicely---
Team 662
Unread 04-17-2003, 12:01 PM
WernerNYK WernerNYK is offline
AKA: Chris Werner
FRC #0190 (Gompei & the HERD)
WernerNYK is a jewel in the roughWernerNYK is a jewel in the roughWernerNYK is a jewel in the rough
Send a message via AIM to WernerNYK
Although I saw many teams use the provided miter boxes, I did not see any robot that used them in the way that we did.
We put the motors on the side 90 degrees of where the FIRST plans had them. We gave a straight output to our main drive. Using the helical gears (lightened and on one side set of right-hand gears opposed to the provided left-hand), we provided a 90 degree drive to our "crab" wheels. So, we effectively had 1 input and 2 outputs from each of the miter boxes.
This really is the best picture that I have exhibiting how we used them; our crab wheels go inside the aluminum 2x4s where the triangles move up and down:
Name:	dsc00571 (small).jpg
-Chris Werner
"Production Manager"
BattleCry@WPI
Team 190 - WPI & Mass Academy
Est. 1992!
Team 871 - Former team leader
The Death of FIRST Anton Abaya General Forum 23 05-03-2006 05:18 PM
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 03-31-2003 07:34 PM
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 02-28-2003 12:18 AM
More 'Best' Robots (a well thought list) archiver 2000 2 06-23-2002 11:11 PM
Disqualifications archiver 1999 13 06-23-2002 09:53 PM
