Go to Post Bring on the competition! And of course the dancing. :D - booton [more]
View Poll Results: Did you like the new drill motors?
Yes 48 68.57%
No 22 31.43%
Voters: 70. You may not vote on this poll
Unread 17-07-2003, 00:25
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
Originally posted by Veselin Kolev
And if I remember correctly, beryllium can be used to make extremely strong and light alloys of aluminum, at a relatively small cost compared to making other alloys. And it isn't radioactive.
So that's why they made Beryllium illegal... I'd been wondering why anyone would want to use it. It makes sense, I suppose.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 17-07-2003, 00:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Originally posted by Cory
Teams want more drill motors because they are very easy to mount compared to the Atwoods, they have a shaft that can easily be coupled to another shaft with gears/sprockets on it, and they can be shifted with fairly little fabrication of other parts
I'll give you the shifting but I find the other two points rather untrue. The Chia can be mounted to a 3x3 angle (or other vertical member or plate) with two 10-24 machine screws and 3/4 clearance hole for the projection in the center of the faceplate of the motor. As for adaptation, with the provided couplers the Chia was just as easy to adapt this year as the drill (2002 was hard though).
A couple more points in favor of the drill and gearbox:
It can often be used with only a single stage reduction (using the Bosch gearbox). The Chia requires a lot more reduction since it doesn't have a gearbox already. Another thing is, this year's drills were more powerful than the Chias in terms of wattage.
Chiaphua Motors: Good or Bad to 2002 Kit Of Parts? D.J. Fluck Motors 25 05-07-2002 16:40
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
what about the drill motors? Ken Leung Motors 2 26-06-2001 02:11
