Spotlights seem repetitive
Has anyone else noticed how the same few spotlighted quotes keep showing up? I know a few (like Jack's 71 "walking bot" quote) tend to show up more than others. Is there any reason for this?
Yeah, I noticed that also... http://www.chiefdelphi.com/forums/spotlightlist.php?s= shows that there are 6 pages of spotlights with 30ish on each page...
On that page are they ordered in any particular way or is it randomized? (hey my spotlight came up when I was posting this ) |
I don't at all mean to sound conceited when I say this, but I don't like seeing my own name all the time. Have people just stopped spotlighting others? It was a big rage at first when it came out.
Search those posts! |
mysql's random function is horrible... so I use it to grab 5 'random' records, and then use phps random function to grab a random 1 from those 5. Maybe I'll redesign it, and put a counter in so they are showed evenly...
It's definetly a lot better then when I complained about it last time.
One way that might be easier is to just verify that all 5 spotlights that mysql gives you are different. Since it seems that mysql likes to give the same answer very often, using php's random function to pick from 5 quotes, 3 of which are the same, isn't going to give very good results. |
come on here brandon
![]() ok.. don't really know the setup of the spotlight table.. but I'd guess there's some autoindex. (1-x) So.... SELECT max(spotlight_id) FROM spotlight_list vB query... $pick_this_one = rand(0, $spotlight_id_max); SELECT * FROM spotlight_list WHERE spotlight_id = $pick_this_one Yup... there ya go. ![]() or... I guess you could base it on session time or system time. (IE: total_spotlights % some_value) yeah... i know... i needs 2 queries ![]() OR... assumeing that vB has some "master config" table which takes all the fields/rows and dumps it into an array, you could have a config value max_spotlight. That's like 100 extra bytes and only requires to be run when a post is spotlighted. Jack PS: FYI to anyone.. Brandon really doesn't need the big roadmap i gave him .. I just wanted to have some funedit: the perfict way to bring down cd. Add a field to the user table which is updated every page refresh to the next spotlight_id - Would never get repeates thoLast edited by Jack : 29-04-2003 at 23:42. |
I just approved about 20some new spotlights.
I got behind. Just wanted to let those who care know. Also wondering if the randomization has been any better? |
hehe....
I should make a script that calls different pages and logs which spotlight it gets. If it calls a page every 15 seconds, that's four times a minute. If I run it all night long, (say 11:00pm-6:00am) that's 7 hours. 4*60*7 = 1680 spotlights. woo... that sure would tell you if it really is random ![]() Meh.. mabey this weekend ![]() |
#10
Have it run twice a second...and run it on 20 different machines...each with a T3+. *evil grin*
#11
The source of index.php on cd is 67kb. Therefore, saying that I just ran it every second for 7 hours that would be 1.6 gb of traffic. I don't think brandon would be too happy with me, not of course to mention the load that would be placed on the server ![]() |
#12
Hey all...
Well you're most likely going to yell NERD really loud because of this one, but oh well ![]() As promised, I created a script which called the first 6240 characters from http://www.chiefdelphi.com/forums/index.php evey 10 seconds. All of this data was logged into a database. In total, I have 1837 records. (That's right, I logged the spotlight 1837 times!!) Now, what did I find? Well.. I'm not really great at giving all this stat stuff.. but here what I can figure out ![]() Well... I logged a total of 169 unique spotlight quotes. However, the spotlight list actually shows 171 spotlights. Hehe.. I found the first thing which causes quotes to be selected more often. The most selected quote was: Success is the indescribable feeling you get when you see something you worked so hard on in front of thousands of people. - SlamminSammy Now, why did this quote come up a whopping 24 times?? Well look.. It has to duplicate entries. (Look on the first spotlight page) There is the first bug. I'm going to guess that another "top quote" also is double quoted. I couldn't find the second repeat quickly.. brandon can find it in a snap with a little query. Well... some basic overall stats. The quote most called had 24 times. The least called quotes (with a 4-way tie) had 4. The "avgerage" should have been 10. Ok.. so I really don't know how to give stats for this stuff very well.. Could some little math genius make them? ![]() The only other thing I will say is that, Jeff W (from his first post) said that my quote (Look at 71's 'walking'...) he thought came up more often than others. Well.. personally I don't think I see it too often. But.. Jeff might be right. In my "study" that quote came up 20 times. It was the third highest. Ok... I've attached a zip file which contains two csv files. One is for the # of times the quote appeared and the quote. The other are the raw entries; Time and quote. Thanks all, Jack |
#14
Nerd.
#15
ok.. so I did a little bad thing and didn't realise that the script didn't stop. So.. I've now been running my script once every .75 secs calling index.php
I now have a total of 15742 records... btw: for what those numbers are, the mean is the avgerage number of times the spotlight appeared.. and so on.. therefore, the numbers are the number of times a spotlight appears. here are some stats from them: Code:
Mean 93.14792899 Standard Error 0.904056592 Median 94 Mode 97 Standard Deviation 11.75273569 Sample Variance 138.1267963 Kurtosis 12.75661616 Skewness -2.032873122 Range 112 Minimum 12 Maximum 124 Sum 15742 Count 169 Also.. I attached the raw stats... (not the acutal logs) Can some math nerd tell us what this means? Jack |
| External Spotlights | Brandon Martus | CD Forum Support | 17 | 04-12-2003 21:38 |
| how random are the spotlights? | Joe Ross | CD Forum Support | 7 | 11-01-2003 23:27 |
