Gear spinning wrong way?
I just noticed this but...
In this avatar the center shaft on the large gear is spinning in the wrong direction. The gear is spinning clockwise while the shaft is spinning counterclockwise. Eh... The things you do when you have too much time on your hands *shrugs* *Cringes in fear of Brandon's wrath* Last edited by Jnadke : 08-05-2003 at 01:53. |
I'm so generous that I've decided to contribute to these forums. Attached is the PC (not politically correct but physically correct
) gear.You're welcome Brandon. ![]() Last edited by Jnadke : 08-05-2003 at 01:57. |
*shrug* I just put up ones that had gears.. wasn't looking too closely at them.
I replaced the original with yours. Thanks ![]() |
Almost P.C.
The hubs still are turning faster than the gears!
Umm... no they shouldn't. They would have the same rotational speed since the gears are directly connected to their respective hubs.
Re: Almost P.C.
Maybe I am full of it? Yes, that's it. |
![]() Last edited by Stephanie : 08-05-2003 at 17:38. |
No matter how much math you put into this, the hub and the gear is still one body spinning together. You don't ever see output shaft of motors spin faster or slower than the sprocket attached to it. It would be really scary if it does. Then again, I've seen it happen before.
Tangental velocity... angular velocity.... blah's! ![]() |
#10
Do I get any extra points on the "Are you a geek?" test for coming up with this interpretation? ![]() -dave |
#12
Wow. This thread was started thanks to the free time that we all have found due to the seasion being over. Brandon, be ready. All of us will have this web site ready for any type of inspection that the goverment can throw at us (you are doing one heck of a job your self, though!
| "Automatic Transmission" | Madison | Technical Discussion | 70 | 24-11-2003 09:03 |
| Thunder Chicken CCT | Simon G | Motors | 4 | 03-01-2003 13:18 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
| Shifting Gears -- | Anton Abaya | Technical Discussion | 26 | 22-01-2002 21:49 |
| Drivetrain Help | Jordan | Technical Discussion | 16 | 02-12-2001 12:14 |
