Go to Post How many computer programmers does it take to screw in a lightbulb? Woah, no. That's a hardware problem. - jordie228 [more]
Unread 25-01-2002, 19:03
Ulibrium Ulibrium is offline
#0920 (Lancers)
Ulibrium is an unknown quantity at this point
Send a message via AIM to Ulibrium
Optical Sensors
Yo,
How do you hook optical sensors up? I got one blue wire, one brown wire, one black wire, and one white wire. There is a diagram on that is a little confusing. What I did was I connect the brown wire to one of the digital input pins on the RC, and the blue wire to a ground pin. My result was the switch bit constantly set to 1. My impression from the diagram was to tie the black and white wire together, but it didn't seem to change anything.
Also, I don't have any reflective tape to test this with. I was trying to change the response by covering and uncovering the sensor but that was of no use. Do I absolutely need reflective tape?
Three mathematicians slave over a board full of tensor calculus. One looks to the other and asks... "do you remember what we sent out to prove?"
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
optical sensors great_one411 General Forum 1 15-02-2003 19:54
optical sensors acting strangely rosebud Electrical 10 03-02-2003 00:29
OPTICAL SENSORS??????????????????? NM_programming Technical Discussion 2 13-01-2002 17:41
