Go to Post I would suggest spending a few more hours digesting the manual before you finalize your designs. You seem to have missed a few key rules. - GaryVoshol [more]
Unread 23-05-2003, 22:16
computhief263's Avatar
computhief263 computhief263 is offline
Battlecry...Here We Come!
AKA: "The Freshman"
#0263 (sachem aftershock)
Team Role: Operator
computhief263 is on a distinguished road
Send a message via ICQ to computhief263 Send a message via AIM to computhief263 Send a message via MSN to computhief263 Send a message via Yahoo to computhief263
A ? about the OI compition port
OK, does anyone know if there is any thing else controled through the compition port besides Auto, Disable, and Channel access
im still learning about the control system and the manuals are very explicet in terms of talking about the the compition port
Tom "40Watt" Bigelow
Team Electrical/Court Jester
Proud creator of The dongle that nuked the OI, Dj in a bag, and THPD(strobe lights, a hat, a modified flashlight bulb, and a 12v B&D Firestorm™ flashlight make a good combo!)
Unread 23-05-2003, 23:01
rbayer's Avatar Unsung FIRST Hero
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
rbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of lightrbayer is a glorious beacon of light
Send a message via AIM to rbayer
As far as I know, those are the only three things it's used for other than supplying power to the OI.
New C-based RoboEmu2 (code simulator) available at: http://www.robbayer.com/software.php
Unread 24-05-2003, 15:08
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Rookie Year: 2000
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
I am pretty sure it can probably do other things, but as discussed in other threads (search around there have been several long ones recently) IFI has been very protective of it.
Isn't there also some kind of a TIME variable that is passed into the control system through the competition port? I heard that at one time but it may have just been a rumor.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 24-05-2003, 18:54
Lloyd Burns Lloyd Burns is offline
FRC #1246 (Agincourt Robotics)
Rookie Year: 1997
Lloyd Burns is an unknown quantity at this point
I'd doubt there is a time variable going to the OI via the Comp Port - the OI's processor has its own accurate enough crystal or resonator clock, and goes through a loop of 26 ms, sending out a data stream which has a one-byte "serial" number.
This "serial" number is the packet_num, from which delta_t is derived. It is this new-packet-every-26-ms feature which provides all the timing information the naked RC can get.
At most, the arena controller might have provided a synchronization signal, so that all four competitors could send one packet before the next round - this would only be useful if there were only one transmitter, and with the single transmitter sending all four packets, the minimum time-between-packets would be 50 or more ms. Since this is not so, no sync is needed, so we have no need of sync signal, nor even a master clock.
Unread 24-05-2003, 20:38
dez250 dez250 is offline
54... What a good number!
Rookie Year: 2000
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
from what i have learned about the competition port is as follows but take it with a grain of salt, for i haven't been able to find any print on this:
The Comp port you can change any of the figures on the other ports from there, so remotely the other ports can be changed along with the other 3 all ready listed. plus if memory serves me right its got one voltage out pin, but I'm not sure. again none of this i am 100% sure on but I'm very sure of it... just if you aren't 100% sure yourself of what your doing don't mess with it, cause IFI wont replace or repair your board for misuse or modification of the ports.
~Mike
-Michael Dessingue
Win32 serial port - recieve buffer seanwitte Programming 4 05-11-2003 21:41
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
