Auditory : 32%
Visual : 67% Left : 47% Right : 53% Melissa, you exhibit an even balance between left- and right- hemisphere dominance and a slight preference for visual over auditory processing. With a score this balanced, it is likely that you would have slightly different results each time you complete this self-assessment quiz. You are a well-rounded person, distinctly individualistic and artistic, an active and multidimensional learner. At the same time, you are logical and disciplined, can operate well within an organization, and are sensitive towards others without losing objectivity. You are organized and goal-directed. Although a "thinking" individual, you "take in" entire situations readily and can act on intuition. You sometimes tend to vacillate in your learning styles. Learning might take you longer than someone of equal intellect, but you will tend to be more thorough and retain the material longer than those other individuals. You will alternate between logic and impulse. This vacillation will not normally be intentional or deliberate, so you may experience anxiety in situations where you are not certain which aspect of yourself will be called on. With a slight preference for visual processing, you tend to be encompassing in your perceptions, process along multidimensional paths and be active in your attacking of situations or learning. Overall, you should feel content with your life and yourself. You are, perhaps, a little too critical of yourself -- and of others -- while maintaining an "openness" which tempers that tendency. Indecisiveness is a problem and your creativity may not be in keeping with your potential. Being a pragmatist, you downplay this aspect of yourself and focus on the more immediate, obvious and the more functional |
Your Brain Usage Profile
Auditory : 40% Visual : 60% Left : 47% Right : 52% Amanda, you exhibit an even balance between left- and right- hemisphere dominance and a slight preference for visual over auditory processing. With a score this balanced, it is likely that you would have slightly different results each time you complete this self-assessment quiz. You are a well-rounded person, distinctly individualistic and artistic, an active and multidimensional learner. At the same time, you are logical and disciplined, can operate well within an organization, and are sensitive towards others without losing objectivity. You are organized and goal-directed. Although a "thinking" individual, you "take in" entire situations readily and can act on intuition. You sometimes tend to vacillate in your learning styles. Learning might take you longer than someone of equal intellect, but you will tend to be more thorough and retain the material longer than those other individuals. You will alternate between logic and impulse. This vacillation will not normally be intentional or deliberate, so you may experience anxiety in situations where you are not certain which aspect of yourself will be called on. With a slight preference for visual processing, you tend to be encompassing in your perceptions, process along multidimensional paths and be active in your attacking of situations or learning. Overall, you should feel content with your life and yourself. You are, perhaps, a little too critical of yourself -- and of others -- while maintaining an "openness" which tempers that tendency. Indecisiveness is a problem and your creativity may not be in keeping with your potential. Being a pragmatist, you downplay this aspect of yourself and focus on the more immediate, obvious and the more functional. <I don't agree with this at all. If anything, the only thing that applies is that I do take in situations and act on intuition, but I have no organization and I rarely have indecisiveness as a problem.> |
Auditory : 62% Visual : 37% Left : 64% Right : 35% tom, you are mildly left-hemisphere dominant while showing a slight preference for auditory processing. This overall combination seems to indicate a well-working blend of logic and judgment and organization, with sufficient intuition, perception and creativity to balance that dominance. You will at times experience conflict between how you feel and what you think which will generally be resolved in favor of what you think. You will find yourself interested in the practical applications of whatever material you have learned or whatever situation you face and will retain the ability to refine whatever knowledge you possess or aspects of whatever position you are in. By and large, you will orient yourself toward intellectual activities and structure. Though not rigid, you will schedule yourself, plan, and focus on routine and continuity of operations, rather than on changes and disruptions When changes or disruptions occur, you are likely to consider first how to ensure that such disruptions do The same balance is reflected in your sensory preference. You will tend to be reflective and measured in your interaction style. For the most part, you will be considered objective without being cold and goal-oriented while retaining the capacity to listen to others. Preferentially you learn by listening and maintaining significant internal dialogues with yourself. Nevertheless, you have sufficient visualization capabilities to benefit from using graphs, charts, doodles, or even body movement to enhance your comprehension and memory. To the extent that you are even implicitly aware of your hemispheric dominance and sensory style, you will feel most comfortable in those arenas which emphasize verbal skills and logic. Teaching, law, and science are those that stand out among the professions, along with technical sales and management. * i agree to most of it excluding the whole organization bit, i am not organized in the least. |
Auditory : 64%
Visual : 35% Left : 57% Right : 42% Jonathan, you are mildly left-hemisphere dominant while showing a slight preference for auditory processing. This overall combination seems to indicate a well-working blend of logic and judgment and organization, with sufficient intuition, perception and creativity to balance that dominance. You will at times experience conflict between how you feel and what you think which will generally be resolved in favor of what you think. You will find yourself interested in the practical applications of whatever material you have learned or whatever situation you face and will retain the ability to refine whatever knowledge you possess or aspects of whatever position you are in. By and large, you will orient yourself toward intellectual activities and structure. Though not rigid, you will schedule yourself, plan, and focus on routine and continuity of operations, rather than on changes and disruptions When changes or disruptions occur, you are likely to consider first how to ensure that such disruptions do The same balance is reflected in your sensory preference. You will tend to be reflective and measured in your interaction style. For the most part, you will be considered objective without being cold and goal-oriented while retaining the capacity to listen to others. Preferentially you learn by listening and maintaining significant internal dialogues with yourself. Nevertheless, you have sufficient visualization capabilities to benefit from using graphs, charts, doodles, or even body movement to enhance your comprehension and memory. To the extent that you are even implicitly aware of your hemispheric dominance and sensory style, you will feel most comfortable in those arenas which emphasize verbal skills and logic. Teaching, law, and science are those that stand out among the professions, along with technical sales and management. |
Auditory : 35%
Visual : 64% Left : 56% Right : 43% Daniel, you are somewhat left-hemisphere dominant and show a preference for visual learning, although not extreme in either characteristic. You probably tend to do most things in moderation, but not always. Your left-hemisphere dominance implies that your learning style is organized and structured, detail oriented and logical. Your visual preference, though, has you seeking stimulation and multiple data. Such an outlook can overwhelm structure and logic and create an almost continuous state of uncertainty and agitation. You may well suffer a feeling of continually trying to "catch up" with yourself. Your tendency to be organized and logical and attend to details is reasonably well-established which should afford you success regardless of your chosen field of endeavor. You can "size up" situations and take in information rapidly. However, you must then subject that data to being classified and organized which causes you to "lose touch" with the immediacy of the problem. Your logical and methodical nature hamper you in this regard though in the long run it may work to your advantage since you "learn from experience" and can go through the process more rapidly on subsequent occasions. You remain predominantly functional in your orientation and practical. Abstraction and theory are secondary to application. In keeping with this, you focus on details until they manifest themselves in a unique pattern and only then work with the "larger whole." With regards to your career choices, you have a mentality that would be good as a scientist, coach, athlete, design consultant, or an engineering technician. You can "see where you want to go" and even be able to "tell yourself," but find that you are "fighting yourself" at the darndest times. Most of it doesn't fit. Especially the organization part... |
Auditory : 58% Visual : 41% Left : 64% Right : 35% RogerR, you are mildly left-hemisphere dominant while showing a slight preference for auditory processing. This overall combination seems to indicate a well-working blend of logic and judgment and organization, with sufficient intuition, perception and creativity to balance that dominance. You will at times experience conflict between how you feel and what you think which will generally be resolved in favor of what you think. You will find yourself interested in the practical applications of whatever material you have learned or whatever situation you face and will retain the ability to refine whatever knowledge you possess or aspects of whatever position you are in. By and large, you will orient yourself toward intellectual activities and structure. Though not rigid, you will schedule yourself, plan, and focus on routine and continuity of operations, rather than on changes and disruptions When changes or disruptions occur, you are likely to consider first how to ensure that such disruptions do The same balance is reflected in your sensory preference. You will tend to be reflective and measured in your interaction style. For the most part, you will be considered objective without being cold and goal-oriented while retaining the capacity to listen to others. Preferentially you learn by listening and maintaining significant internal dialogues with yourself. Nevertheless, you have sufficient visualization capabilities to benefit from using graphs, charts, doodles, or even body movement to enhance your comprehension and memory. To the extent that you are even implicitly aware of your hemispheric dominance and sensory style, you will feel most comfortable in those arenas which emphasize verbal skills and logic. Teaching, law,(teaching?!?! LAW!!?!??! oh god i hope not!!! ) and science are those that stand out among the professions, along with technical sales and management. |
Auditory : 61% Visual : 38% Left : 71% Right : 28% Meredith, you are mildly left-hemisphere dominant while showing a slight preference for auditory processing. This overall combination seems to indicate a well-working blend of logic and judgment and organization, with sufficient intuition, perception and creativity to balance that dominance. You will at times experience conflict between how you feel and what you think which will generally be resolved in favor of what you think. You will find yourself interested in the practical applications of whatever material you have learned or whatever situation you face and will retain the ability to refine whatever knowledge you possess or aspects of whatever position you are in. By and large, you will orient yourself toward intellectual activities and structure. Though not rigid, you will schedule yourself, plan, and focus on routine and continuity of operations, rather than on changes and disruptions When changes or disruptions occur, you are likely to consider first how to ensure that such disruptions do The same balance is reflected in your sensory preference. You will tend to be reflective and measured in your interaction style. For the most part, you will be considered objective without being cold and goal-oriented while retaining the capacity to listen to others. Preferentially you learn by listening and maintaining significant internal dialogues with yourself. Nevertheless, you have sufficient visualization capabilities to benefit from using graphs, charts, doodles, or even body movement to enhance your comprehension and memory. To the extent that you are even implicitly aware of your hemispheric dominance and sensory style, you will feel most comfortable in those arenas which emphasize verbal skills and logic. Teaching, law, and science are those that stand out among the professions, along with technical sales and management. ***Yep, I would say that is pretty dead on, which suprises me beucase those were really random questions and I didnt think I was consistant with any of my answers. |
out of complete boredom, i took the test again, and came up with totally different results. o well.
Your Brain Usage Profile Auditory : 37% Visual : 62% Left : 55% Right : 44% Shyra, you are somewhat left-hemisphere dominant and show a preference for visual learning, although not extreme in either characteristic. You probably tend to do most things in moderation, but not always. Your left-hemisphere dominance implies that your learning style is organized and structured, detail oriented and logical. Your visual preference, though, has you seeking stimulation and multiple data. Such an outlook can overwhelm structure and logic and create an almost continuous state of uncertainty and agitation. You may well suffer a feeling of continually trying to "catch up" with yourself. Your tendency to be organized and logical and attend to details is reasonably well-established which should afford you success regardless of your chosen field of endeavor. You can "size up" situations and take in information rapidly. However, you must then subject that data to being classified and organized which causes you to "lose touch" with the immediacy of the problem. Your logical and methodical nature hamper you in this regard though in the long run it may work to your advantage since you "learn from experience" and can go through the process more rapidly on subsequent occasions. You remain predominantly functional in your orientation and practical. Abstraction and theory are secondary to application. In keeping with this, you focus on details until they manifest themselves in a unique pattern and only then work with the "larger whole." With regards to your career choices, you have a mentality that would be good as a scientist, coach, athlete, design consultant, or an engineering technician. You can "see where you want to go" and even be able to "tell yourself," but find that you are "fighting yourself" at the darndest times. |
my response:
Auditory : 46% Visual : 53% Left : 52% Right : 47% Michael, you exhibit an even balance between left- and right- hemisphere dominance and a slight preference for visual over auditory processing. With a score this balanced, it is likely that you would have slightly different results each time you complete this self-assessment quiz. You are a well-rounded person, distinctly individualistic and artistic, an active and multidimensional learner. At the same time, you are logical and disciplined, can operate well within an organization, and are sensitive towards others without losing objectivity. You are organized and goal-directed. Although a "thinking" individual, you "take in" entire situations readily and can act on intuition. You sometimes tend to vacillate in your learning styles. Learning might take you longer than someone of equal intellect, but you will tend to be more thorough and retain the material longer than those other individuals. You will alternate between logic and impulse. This vacillation will not normally be intentional or deliberate, so you may experience anxiety in situations where you are not certain which aspect of yourself will be called on. With a slight preference for visual processing, you tend to be encompassing in your perceptions, process along multidimensional paths and be active in your attacking of situations or learning. Overall, you should feel content with your life and yourself. You are, perhaps, a little too critical of yourself -- and of others -- while maintaining an "openness" which tempers that tendency. Indecisiveness is a problem and your creativity may not be in keeping with your potential. Being a pragmatist, you downplay this aspect of yourself and focus on the more immediate, obvious and the more functional Hehehe ~Mike |
#10
Auditory : 50%
Visual : 50% Left : 49% Right : 50% Heidi, you exhibit an even balance between left-and right- hemisphere dominance and an even split between your auditory and visual processing. With a score this balanced, we recommend you take the quiz again. Okay, so you did, and the score was the same. We’ll continue. You are a distinctively unique, individualistic, one of a kind, artistic person (we will not say well-rounded, the last time we said that to a woman, we got slapped). When you want to be, you are an active and multidimensional learner. It is a good thing you have a natural instinct for things because logic rarely enters into the picture with you and discipline is a word you openly scoff at. Still, you are organized (eh… maybe…) and if not goal directed, you at least know you have some goals to reach. Your usual learning style is to absorb things as though through osmosis, unless of course you are not interested in learning what is being taught and then not even a sledgehammer will get it through your thick skull. You will alternate between instinct and impulse and your natural instinct will almost always lean towards being impulsive. Due to you missing 1% (don’t think we didn’t notice) you will tend to lean a bit towards using your talents for evil. Okay, not really for evil, but you are often up to no good, and you know it. With an equal preference for visual and auditory processing you tend to be confused as to whether or not to believe in what you see or what you hear. And you can never decide if you liked the book better than the movie. Overall, we would like to tell you to be content with your life, but we’re still confused by the missing percent. You could probably cut back on the sarcasm a little. Your indecisiveness is a problem (come on, everyone knows the book is always better than the movie) that could wreak havoc on your creative potential. Being a optimistic pessimist, you rationalize this aspect of yourself and focus on the more immediate and obvious situations at hand (such as finding out who really does make the best pickles in the world.) MissInformation <============> Half empty or half full, I only notice when it's completely empty. |
#11
Auditory : 38%
Visual : 61% Left : 47% Right : 52% ...is this supposed to add up to 100%?...cause it doesnt.... Anne, you exhibit an even balance between left- and right- hemisphere dominance and a slight preference for visual over auditory processing. With a score this balanced, it is likely that you would have slightly different results each time you complete this self-assessment quiz. You are a well-rounded person, distinctly individualistic and artistic, an active and multidimensional learner. At the same time, you are logical and disciplined, can operate well within an organization, and are sensitive towards others without losing objectivity. You are organized and goal-directed. Although a "thinking" individual, you "take in" entire situations readily and can act on intuition. You sometimes tend to vacillate in your learning styles. Learning might take you longer than someone of equal intellect, but you will tend to be more thorough and retain the material longer than those other individuals. You will alternate between logic and impulse. This vacillation will not normally be intentional or deliberate, so you may experience anxiety in situations where you are not certain which aspect of yourself will be called on. With a slight preference for visual processing, you tend to be encompassing in your perceptions, process along multidimensional paths and be active in your attacking of situations or learning. Overall, you should feel content with your life and yourself. You are, perhaps, a little too critical of yourself -- and of others -- while maintaining an "openness" which tempers that tendency. Indecisiveness is a problem and your creativity may not be in keeping with your potential. Being a pragmatist, you downplay this aspect of yourself and focus on the more immediate, obvious and the more functional |
#12
I think you scored higher on left brain than you really are. ![]() Last edited by Greg Ross : 10-06-2003 at 17:28. |
| White Paper Discuss: 2003 Automated Dead Reckoning Test Code | CD47-Bot | Extra Discussion | 10 | 07-09-2005 11:25 |
| Extra ramp and platform outside the field at each event to test and practice? | Digo | General Forum | 4 | 19-01-2003 21:39 |
| Anyone know how to test motors?? | archiver | 2000 | 2 | 23-06-2002 22:21 |
| NEED A BRAIN? | archiver | 1999 | 0 | 23-06-2002 22:07 |
| Test Track- Ride A Thon!! | Joe Matt | Championship Event | 19 | 14-04-2002 22:53 |
