Go to Post Mountain Dew and Taco Bell. Nom Nom Nom. - R.C. [more]
Unread 20-06-2003, 14:02
dddriveman's Avatar
dddriveman dddriveman is offline
Former Driver 1038, 979
AKA: Driveman
FRC #1038 (Thunderhawks)
dddriveman has a spectacular aura aboutdddriveman has a spectacular aura about
Send a message via AIM to dddriveman
Creative uses for servos?
If anybody has any creative uses or has any good ideas on how to use servos on a robot please share them here.
"I'm sorry, after all he is just a wookie!"
Unread 20-06-2003, 14:08
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
shift the drill gearboxes with them
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 20-06-2003, 14:56
dddriveman's Avatar
AKA: Driveman
I"m not sure how you would do that!
Unread 20-06-2003, 15:00
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Well, you would need to fabricate a servo mount and a custom shifting linkage.
Another good use for servos is to mount sensors on to scan back and forth for HP stacks or other reflective tape.
Unread 20-06-2003, 15:02
jon jon is offline
jon has a spectacular aura aboutjon has a spectacular aura aboutjon has a spectacular aura about
Attach them to the shaft collar on the drill motors, so that when the servos are rotated, the collar shifts positions.
Though, this is not longer very original, anymore.
dddriveman's Avatar
AKA: Driveman
thanx for the idea sanddrag
Unread 20-06-2003, 15:50
Team Role: Teacher
Check the white papers for the servo shifting. There are a couple designs in there.
Unread 20-06-2003, 19:16
dddriveman's Avatar
AKA: Driveman
I'll check the white pages for Servo shifting. Thanks again sanddrag
Unread 21-06-2003, 21:50
Mike Schroeder's Avatar
Mike Schroeder Mike Schroeder is offline
Gone the way of the dinosaur
AKA: "Big Mike"
Rookie Year: 1999
Mike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond reputeMike Schroeder has a reputation beyond repute
Send a message via AIM to Mike Schroeder Send a message via Yahoo to Mike Schroeder
we used servos to engage.. disengage our brakes
GOT SEARCH?
"We choose to go to the moon. We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard"-JFK
Unread 21-06-2003, 22:58
Sully Sully is offline
no team (The Bobcats)
Rookie Year: 1994
Sully is on a distinguished road
Send a message via Yahoo to Sully
Clever use of a servo motor
In Houston I found one team using a servo as a vacuum release mechanism for their suction cup. The servo was used to close or pinch off a piece of tubing thereby keeping their suction cup fully engaged. If necessary the servo would open the tube - releasing the vacuum. A clever and simple release mechanism.
Often servos are used as release mechanisms at the beginning of matches so that a robot can expand outside its constrained envelope.
Unread 22-06-2003, 18:21
dddriveman's Avatar
AKA: Driveman
I found a way to flip down the motor the powers the flashing lights on our robot. THE motor is spring loading so you can make the light spin or not spin . Useless but, fun
Unread 22-06-2003, 19:12
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
Ian W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to allIan W. is a name known to all
Send a message via AIM to Ian W.
just don't do that in an official competition
AIM --> Woloi
Email --> ian@woloschin.com
Unread 23-06-2003, 09:17
dddriveman's Avatar
AKA: Driveman
I know. But when you are not in competition it is fun to do.
Unread 23-06-2003, 20:06
JLambert's Avatar
JLambert JLambert is offline
#0151 (Wild Cards)
JLambert is an unknown quantity at this point
Send a message via ICQ to JLambert Send a message via AIM to JLambert Send a message via Yahoo to JLambert
Also, if you wedge a small disc on between the pinion (like, say, a small piece of a glue stick), the light will turn at a little over 2x the normal speed. Again, not legal, but fun to mess with when you have nothing else to do.
Not that our team would ever be sitting around, or ever be doing ANYTHING like that...
Justin Lambert
02-03: Programmer Team #151
  #15   Spotlight this post!
Unread 24-06-2003, 14:21
Rickertsen2 Rickertsen2 is offline
Umm Errr...
None #1139 (Chamblee Gear Grinders)
Rickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant futureRickertsen2 has a brilliant future
Send a message via AIM to Rickertsen2 Send a message via Yahoo to Rickertsen2
you can also short the resistor in the light to make it go faster. Again not legal but fun anyway. Its also interesting to hook it up to a speed controller. lol
Anyway i'm not sure if this counts but i made this from the FIRST provided servos.
1139 Alumni
pic: creative shirt CD47-Bot Extra Discussion 3 17-03-2003 23:08
FIRST and Creative Mediums archiver 2001 1 24-06-2002 04:11
Hi Colleen archiver 2000 2 23-06-2002 22:03
weight advice SharkBite Technical Discussion 36 15-02-2002 07:30
User Titles Brandon Martus CD Forum Support 27 04-06-2001 22:23
