Penumatic Flow Control Valve
Okay... the pneumatic manual clearly states that the flow control valves should be put *directly* on the cylenders. However, our mentor from Festo last year told us to put the flow control valves on the output ports of the solinoids. This set-up works... but... is there some reason why the manual says we should put them on the cylenders?
| Need a FIRST Robotics control system | kershawrobotics | General Forum | 3 | 07-07-2003 09:49 |
| Ok, how much is the control system worth? | archiver | 2001 | 6 | 23-06-2002 22:05 |
| more control options | smokescreen | Technical Discussion | 17 | 05-03-2002 15:41 |
| goals: how much control? | Pat Sarmiento | Rules/Strategy | 2 | 18-01-2002 19:10 |
| how do u hook up things through the fuse panel? | chrisw | Technical Discussion | 9 | 12-01-2002 19:51 |
