#46
M. Krass
Although I do Love your Critical essays To me All you realy had to say was....
"So tytus, You dont have the numbers?" And here is an intresting pdf... www.army.mil/usapa/doctrine/DR_pubs/ dr_a/pdf/fm1_514.pdf id like to point out the part on the combining transmition Im still looking for more info... so its on the way Last edited by Tytus Gerrish : 29-06-2003 at 16:39. |
#47
... and she's right. You just say "add everything and it's better"
Perhaps create a white paper, one with calculations, better (and by better, I mean easier to understand) drawings with less fancy textures, and then really ask what people think. |
#48
Hey Tytus - just curious, did you make all that in 3D Studio Max, or did you import some stuff from CAD/Inventor into 3D Studio Max??
Also, taking in some of what people have said here.. it is true that you can't really judge any real-world attributes of objects in 3D Studio Max... unless you have certain add-ons/settings that allow that... Inventor/CAD would be a much better help if you try to do some math and test some things before ya build it. Design looks interesting, keep at it ![]() |
#49
Re: M. Krass
<edit> Because of the fact that that PDF is image based, you can't search through it. Also, actual information pertaining to a "combining transmission" seemed a little lacking. This irked me a little, so I searched around a little. </edit> Other than that, upon my own investigation of "combining transmissions," it seems they're only used in rotary aircraft (helicopters [namely the Chinook] for the most part). Here's another website that explains the CH-47 drivetrain's usage of a "combining transmission," or "C-Box," as they like to call it. The images on their website are artificially shrunk, so here're some links to the actual full-size images: Diagram of CH-47 drivetrain, focusing on how the assembly is integrated into the body of the aircraft. Conceptual diagram of the actual mechanical set-up of the system. Assuming the engines are the same, in the concept diagram, they output 15066rpm, which goes through a ~1.23:1 reduction, taking it to 12263rpm, which goes through another reduction of ~1.77:1, taking it to 6912rpm, which goes to the two independant (somewhat) rotors, which have their own ~30.72:1 reduction, before the output shaft (the rotor) which is a nice and manageable 225rpm. I have no idea what I added to this thread, probably nothing, but there's a little more information about practical usage of this kind of system. *beats a dead horse* And just for the record, I still love Google. Last edited by FotoPlasma : 29-06-2003 at 19:59. |
#50
Re: M. Krass
If you can manage to build it and make it work, good for you. If you happen to manage to do that by pulling it straight out of your behind, I don't care. I've done what I can to provide a better explanation as to how and why this may operate and how and why it can be improved. If you're not interested in learning from that, I'm not interested in providing it. You have a lot to learn about everything. Good luck. Last edited by Madison : 29-06-2003 at 20:29. |
#51
ok... Ill build it, ill prove it works, Ill change the way multi-motor drives are built Forever!
(ok, getting a little ahead of myself there.... ,At least ill build it) |
#52
A friend of mine directed me towards the Toyota prius (and i suppose other hybrid cars.) They have two inputs at varying speeds and combine them to produce one output. Unfortunatly i haven't been able to find a good source of information on the topic of their transmissions but i'm still searching. Might be good place to look for more info.
I'm starting to edge towards beltless CVT though... ![]() |
#53
But if they do use both at once - they can use a viscous coupling, and I'm sure that can help in its moments... |
#54
That said, after a little searching, I found this, a comparison between the Honda Insight and the Toyota Prius regarding their drivetrains. According to the various diagrams of energy flow (mechanical and electrical) in various states of use (stationary, starting up, accelerating, cruising, and decelerating/regenerative breaking), it seems as though both the electric motor and the internal combustion engine are used in tandem much of the time, in the Prius (and obviously less of the time in the Insight, but it still happens). |
#55
The neat thing, however, is that the power created by the generator (when the batteries are full), is sent to a motor that is directly connected to the driveshaft that, ultimately, leads to the wheels (after the planetary gear system). So, contrary to belief, the Prius planetary gearbox does not have two inputs. Its planetary gearbox actually has one input and two outputs. The only exception to this is when it is using regenerative braking. Quote:
2. If you've learned anything from the explanation of the Prius above, you cannot exert more torque than the weakest motor (believe me, if Toyota could operate at greater than 100% efficiency, they would). Once you do, it will act as a generator. The power output of the remaining motor will be split between the wheels and the generator. The bad thing is, all the speed controllers do with this generated power is get rid of it, as heat. Basically, this limitation makes this system bad for pushing applications (when using motors with dissimilar torques). 3. Actually, I got the idea from a patent when I was surfing the internet. Technically, it's not your device. It belongs to the guy that patented it. Beyond usage for non-profit applications, you have no rights to it. Differential electric engine with variable torque conversion Continuously variable transmission system Continuously variable gear drive transmission Electric constant speed/variable speed drive/generator assembly There's a lot of neat stuff floating around in the patent database. All of it is free range to us since we're using it not-for-profit. Sometimes when I have an idea I search there to see if there's a better idea or to see if it's feasible. Quote:
#56
50% is good...
Worm & Worm gear combos are not typically even 50% efficient.
There is a very good match between effeciency and backdriveability so in the case of the the Thunderchicken drive, they were probably way under 50% or else the system would have been backdriveable. Joe J. |
#57
A Dual-engine helocopter Roto-train
#58
That's pretty neat however is appears that each motor would be spinning at the same speed. Have you tried it with different gearing on one motor?
#59
Urmm.. having them at different speeds (in that orientation) will definitly cause a generator. Give it a whirl, program the rcx so one is going 100% and the other 50-80% Should be some interesting results.
Edit: If you have a rotation sensor, maybe you could get some good feedback? |
#60
thats exactly what i did Boyo! |
| pic: LEGO Vernier Gearbox | CD47-Bot | Extra Discussion | 9 | 10-10-2003 09:43 |
| pic: dual speed gearbox | CD47-Bot | Extra Discussion | 9 | 07-10-2003 15:04 |
| pic: Gerrish Gearbox MK-III #2 | CD47-Bot | Extra Discussion | 26 | 12-09-2003 11:35 |
| pic: Gerrish Gearbox MK-III | CD47-Bot | Extra Discussion | 22 | 04-09-2003 16:32 |
