Go to Post Glue it, screw it, bolt it, rivet it, weld it. If the design is flawed it will fail. - Gdeaver [more]
Unread 17-07-2003, 16:54
MarkF's Avatar
MarkF MarkF is offline
MarkF is an unknown quantity at this point
Send a message via AIM to MarkF Send a message via Yahoo to MarkF
Monitor Trouble....Help!
I was online earlier and my Motorolla Cable Modem decided to wig out on me (in other words, it started turning itslef off and on randomly). I rebooted, thinking maybe my computer just needed a rest. When my system was ready to roll again, the screen resolution was down to 640X480 and the colors were set to 16. I went into the setting and it wouldn't let me change back to 1164X864 and 16 bit High Color. If I made the color 256 colors, it wouldn't let the screen be any larger than 640X480, and if I made the screen any bigger than that, it wouldn't let me get better that 32 colors. What is goin on here? (I tried reintalling the driver for the monitor via the recovery disk...no help there.)
AIM: Vidgamer1986WHS
email: dodge4186@comcast.net
"I have a 6-pack!" *flexes*
"I have an 8-pack!" *flexes more*
"I have a keg!" *lets it just hang*
Unread 18-07-2003, 03:34
Unsung FIRST Hero
Nate Smith Nate Smith is offline
FRC Key Volunteer Trainer
AKA: CrazyNate
Rookie Year: 1998
Nate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to beholdNate Smith is a splendid one to behold
Send a message via AIM to Nate Smith Send a message via Yahoo to Nate Smith
Sounds like a video card driver issue,and not a monitor issue, so here's what you want to try:
1. Reinstall the video driver & Reboot
2. If it doesn't correct itself, adjust it to the highest resolution it will let you pick, then reboot again.
3. After the second reboot, it should give you all your options back. In some cases, I've seen a need with some video drivers to need to get out of the default 640x480x16c mode before they will let you get any fancier than that. An easy way to tell(in most cases) if you have one of these drivers is if after getting out of 640x480x16c, it asks you to reboot for the changes to take effect...
Nate Smith
nsmith@smythsoft.com
12 seasons, 4 teams, and more time logged behind the scorekeeper's table than I care to remember...
returning for 2011? only time will tell...
Unread 18-07-2003, 13:45
Coco the Monkey's Avatar
Coco the Monkey Coco the Monkey is offline
Anyone up for some Hot Coco?
AKA: Vince Moore, or Coco
FRC #0768 (The TechnoWarriors)
Coco the Monkey will become famous soon enoughCoco the Monkey will become famous soon enough
Send a message via AIM to Coco the Monkey Send a message via MSN to Coco the Monkey Send a message via Yahoo to Coco the Monkey
Nate's way will problubly work, but my friend was having resolution issues before, and it ended up being a virus that created a mock monitor's file, so when he tried to change the resolution it was in a fake program.
He did a virus scan and nuked it.
Thats what he told ME anyway.
2007-Present: Mentor of team 768 The Technowarriors
2001-Present: Member/Alumni of team 365 The Miracle Workerz GO MOE!
I'm seeing a pattern in the teams I've been a part of... Gotta love the green
AIM: ArtXCoco
Unread 18-07-2003, 15:29
MarkF's Avatar
My computer is refusing to cooperate. I did a virus scan, tat found nothing. Might there be something hidden? Also, when I try to change any of the settings, and I click apply, they flick back to minimum resolution and colors, just before the window dissapears. Why is it doing this?
