Go to Post The most important deisgn criteria is always performance in any of the parts / systems we design. But we do try to abide by the saying -- if it doesn't look good (right), it probably isn't good (right). - Adam Freeman [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 22-07-2003, 23:30
KWachowski27
Posts: n/a
Slip Ring
Well now, where were we? Slip rings are good and ummm, they should be allowed... or something.
Unread 22-07-2003, 23:38
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Rookie Year: 2000
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
somebody asked what their main purpose was...
That rug really tied the room together...
Unread 23-07-2003, 00:08
Matt Krass's Avatar
Matt Krass Matt Krass is offline
"Old" and Cranky. Get off my lawn!
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Matt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond reputeMatt Krass has a reputation beyond repute
Send a message via AIM to Matt Krass
If I'm not mistaken the one they started is MIA due to server 'hiccup'.
Matt Krass
If I suggest something to try and fix a problem, and you don't understand what I mean, please PM me!
I'm a FIRST relic of sorts, I remember when we used PBASIC and we got CH Flightsticks in the KoP. In my day we didn't have motorized carts, we pushed our robots uphill, both ways! (Houston 2003!)
Unread 23-07-2003, 00:14
Jeff Waegelin's Avatar
Jeff Waegelin Jeff Waegelin is offline
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Jeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond reputeJeff Waegelin has a reputation beyond repute
Originally posted by Cory
there is no need to start a new thread. please respond in the one you started yesterday.
Cory
That thread was deleted, somehow. If you look at Brandon's announcement about "downtime" he said the Slip Ring thread is MIA.
Jeff Waegelin
Mechanical Engineer, Innovation First Labs
Lead Engineer, Team 148 - The Robowranglers
Unread 23-07-2003, 00:18
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
oops, sorry about that guys
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 23-07-2003, 00:23
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Cory
It seems as though that thread was the only casualty of the downtime, today.
Anyway, earlier today, I found two questions about using slip rings on the jive.ilearning.whatever message board, both of which had answers which practically stated that they would need to be on the Restricted Parts List to be legal robot material, however, as M. Krass pointed out, Anderson Power's connectors aren't on said list, but are "quick disconnect" components. You might be able to argue that slip rings are a saftey feature, and, if they have the kind of lax inspection system as this and previous years (doubtful), you might be able to get away with it.
However, again, I believe there was a post in the previous thread stating that other teams (66 in 2002, was it?) have used slip rings without penalty.
So, it seems to be rather up in the air, at this point...
<edit>
Joe Ross was kind enough to point out that, on the Restricted Parts List of 2003, there was this specific item:
From page 43 of The_Robot.pdf
Electronics:
Insulated Electrical Connectors:
Any amount/size, off-the-shelf, proper gauge/current rating
To my knowledge, this means that as long as a slip ring is "off-the-shelf" and properly insulated, it's entirely legal.
Just a little more stirring of the water...
</edit>
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Presenting the FIRST forum ring archiver 2001 0 24-06-2002 00:42
motor high gear/low gear switch... archiver 2001 6 23-06-2002 23:50
O rings to lock drill in High tareyton Technical Discussion 6 26-01-2002 14:13
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
Lots of play in Drill Motors!!! Todd Lawless OCCRA 3 03-11-2001 19:18
