Go to Post Dave Lavery was right... all we had to do was type in "attack old lady" and when we started up our robot it did. - Human Player [more]
Unread 29-01-2002, 21:51
Joseph F Joseph F is offline
#0506 (Steel Friars)
Joseph F is an unknown quantity at this point
Send a message via AIM to Joseph F
shaft drive
Were planning on doubling up our wheels on the drive axle. Last year with a single wheel we had a fixed axle and attached the sprocket directly to the wheel. Whats a good way of connecting the wheels and sprocket to the shaft without using a keyed shaft. Should we drill clean through the shaft and wheel hub and put a screw through it? drill a hole in the hub only and find a way to set screw it? or is there a better way? btw we are using 1/2" diamater shafts if that makes a difference.
One Team, One Bot, One Fleet of Ambulances!
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
Motor coupling archiver 2001 19 23-06-2002 23:35
drill motor drive shaft attachment archiver 2001 1 23-06-2002 22:32
"Motors and Drive train edition" of Fresh From the Forum Ken Leung CD Forum Support 6 29-01-2002 12:32
