Go to Post Woo for speculation! - Eugenia Gabrielov [more]
Unread 08-23-2003, 12:57 AM
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
G4 wont turn on!
Hey Guys,
Someone plugged in one of our G4s and there was a big spark (from the outlet) and now it wont turn on. I press the button nothing happens.
I opened the case, no signs of shock. I popped the batt.
Still nothing, I am fearing the worst. Anyone have this happen be4?
The views expressed in my posts are Mine and mine only.
my myspace!
Unread 08-23-2003, 12:59 AM
AlbertW's Avatar
AlbertW AlbertW is offline
harker robotics :. 1072
AKA: Aonic
#1072 (Harker Robotics)
AlbertW is on a distinguished road
Send a message via AIM to AlbertW
You probably fried your power adapter. (the big metal block in the corner of your computer)
send it in to apple. If you're feeling adventurous you could probably go buy a PC one and replace it, but I don't know the specs of it and wouldn't recommend it.
edit: on another thought, the power adapter usually has fuses in it that can be replaced. BUT opening it is EXTREMELY dangerous as the capacitors in there usually hold charge long after it's been unplugged. so don't do it.
We were the first seeded first-year team at a first-year FIRST regional.
Unread 08-23-2003, 01:00 AM
MattK's Avatar
Tap it.
thats what I thought, I have a couple old PC PSs hanging around. although they wont fit the motherboard on the mac.
I really hope it didnt get any further than the PS.
my myspace!
Unread 08-23-2003, 01:23 AM
ZACH P. ZACH P. is offline
Insert Custom User Title
#0321 (Robolancers)
ZACH P. is on a distinguished road
Send a message via AIM to ZACH P.
If your careful and you know what your doing, then working with the PSU should be no problem. Also, even if the PC supply wont fit in the case you can still rig it to test and see it the computer works with it, and that it really is the power supply thats broken.
pi is exactly 3
IM me at: zmstr265
Unread 08-23-2003, 02:30 AM
AlbertW's Avatar
AKA: Aonic
i think the actual port on the motherboard is different, and therefore a PC adapter won't plug in.
try and find a used g4 adapter on ebay.
Unread 08-23-2003, 10:25 AM
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
be adventurous. cut a few wires. solder a few plugs.
Anyway, why did it spark in the first place? Was it a 220 outlet?
Unread 08-23-2003, 01:45 PM
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
220 outlets generally have different sockets and won't fit a 115 (standard) cord. (i should know. . . I spent the summer building infrared heaters . . some were 115 volt, some were 120 volt, and some were 230 volt (220 in europe))
anywho, try a different outlet.
It sounds like a bad outlet, you may have popped a breaker somewhere.
If different outlet doesn't work, you probably friend your power supply (what the other guy called power adapeter: the big box of transfromers in the corner, with all the power wires coming out of it on the inside)
If that is the case . . . go to www.newegg.com and buy a new one. Antec PSU's are generally considered to be the best (cleaner power = longer system life)
or just send it to the apple people and the will fix it in return for a glowing customer testimonial.
Unread 08-25-2003, 12:04 AM
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Rookie Year: 1999
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
Was there any arc ing? Did the spark leave any scorch marks?
Or did it just flash?
Wetzel
You Lose.
Unread 08-25-2003, 07:16 AM
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I am just guessing here but my wife's IBook is notorious for bad power cord. If this is an older machine and you have used the power plug often, (i.e. moved the machine and needed to replug the power.) then you may have a damaged cord. Did the arc take place on the cord or inside the outlet?
There is certainly fuses somewhere in the power supply but these are best handled by an expert.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 08-25-2003, 11:05 AM
jon jon is offline
jon has a spectacular aura aboutjon has a spectacular aura aboutjon has a spectacular aura about
Could be the outlet as well.
And I'm confused as to what this has to do with FIRST in the first place. Wouldn't a question like this be better answered in a forum for, say, computer hardware?
Unread 08-25-2003, 04:59 PM
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
FRC Video Review - Change is Coming
FRC #4329 (Lutheran Roboteers)
Team Role: Coach
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
/begin shameless Mike Nelson plug
Call Radioshack and see... their entire business seems to be based almost entirely around spare cords...
/end shameless Mike Nelson plug
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 08-25-2003, 08:35 PM
Kevin A Kevin A is offline
In Hibernation
#0481 (DART)
Team Role: Mechanical
Rookie Year: 2000
Kevin A will become famous soon enough
Send a message via AIM to Kevin A
::so tempted to diss on macs::
Unread 08-25-2003, 10:42 PM
AlbertW's Avatar
AKA: Aonic
dude, what's your problem?
a surge can hit any computer. will kill them equally.
Unread 08-26-2003, 12:36 AM
In Hibernation
#0481 (DART)
Rookie Year: 2000
Thats why i didnt diss on them. I personally dont like the mac interface or unexpandability. I know that a surge can hit any computer, its just an easier cheaper fix if its a pc.
  #15   Spotlight this post!
Unread 08-26-2003, 09:44 AM
AlbertW's Avatar
AKA: Aonic
Originally posted by Kevin A
Thats why i didnt diss on them. I personally dont like the mac interface your choice or unexpandability wrong. I know that a surge can hit any computer, its just an easier cheaper fix if its a pc. true
College Advisor turn outs Guyute General Forum 4 06-20-2003 01:35 PM
It's the girls turn now...... SPAMcutie180 Chit-Chat 260 04-17-2003 10:26 PM
10 turn 100k pots rust710 Electrical 5 04-02-2003 03:10 PM
PWM Antonio Technical Discussion 21 01-06-2003 02:44 PM
turn in time moogie 3D Animation and Competition 1 02-18-2002 10:32 PM
