Go to Post Wow... no duct tape? - Stormnnormn [more]
View Poll Results: Should Weigh in be With or Without Battery
With 31 55.36%
Without 19 33.93%
Weight Limit should be increased to make things more exciting. 6 10.71%
Voters: 56. You may not vote on this poll
Unread 04-09-2003, 21:27
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Rookie Year: 2000
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
By what you're saying, it seems there are teams out there using cardboard batteries during weigh in.
I don't think a team would get to the point to use a dummy battery, in the sense of a hollow one or something like that. What I have read here in the forums is that some teams use really old batteries for inspection, as it is a known fact that they actually get lighter with time. It is a cheap shot, nonetheless, but you can always blame it on the freshman member for putting it in place, in case you get caught.
So, yes, I think the robot should be weighted without the battery in place, or at least some "official" one, standardized to every team.
Manoel Flores da Cunha
Mentor
Brazilian Machine
Team # 383
Unread 04-09-2003, 22:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I think the latter part of this quote is an excellent idea. Have one, brand new battery (or other consistant weight) at every regional event. You take your robot to the scale without the battery and this battery is placed on the scale with your robot (and everyone else's). The weight limit remains the same. How about that?
Oh, and don't try to place your toe under the scale and lift up while your robot is being weighed. They look for that too. (although it is helpful and okay to fudge with it a little up and down before the acutal reading is taken to ensure an accurate measurement.)
Unread 04-09-2003, 22:22
Manoel's Avatar
Rookie Year: 2000
Originally posted by sanddrag
Oh, and don't try to place your toe under the scale and lift up while your robot is being weighed. They look for that too. (although it is helpful and okay to fudge with it a little up and down before the actual reading is taken to ensure an accurate measurement.)
That may be a good idea.
Last year we were weighting the robot in Seattle and the scale would range from 130 to 130.5, so *someone* (was it me? ) had the brilliant idea to empty the air tanks to see if it would help - heck, the air above us weights a whole lot .
Well, the scale actually went half a pound up... Go figure
"And the robot got some nice speed holes..."
Mentor
Brazilian Machine
Team # 383
Unread 04-09-2003, 22:58
Mike Rush's Avatar
Mike Rush Mike Rush is offline
Somewhat Insightful
FRC #4154 (Perpetual Recursion)
Rookie Year: 1996
Mike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really niceMike Rush is just really nice
I must admit...
If we were close at weigh in, we would weigh all of our available current year batteries and choose the lightest one. This helped us a little and also fell well within the spirit of GP and FIRST.
Mike Rush - Engineer/Mentor
Perpetual Recursion (4154)
Arizona Community Team (1492)
2004 AZ Regional Woody Flower's Award
Basha High School & Intel (1456)
Gila Monsters (64)
Awards!?! Too many to list...
Unread 04-09-2003, 23:27
Dave Flowerday Dave Flowerday is offline
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Dave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond reputeDave Flowerday has a reputation beyond repute
Why not simplify a little bit and just figure out the average battery weight and subtract it from the total allowed weight, and allow teams to weigh in without the battery? Net result should be the same...
For example, if the official battery is deemed to weigh 14 pounds, just make the weight limit 116 pounds, and have everyone weigh in w/o the battery.
Unread 05-09-2003, 00:09
Manoel's Avatar
Rookie Year: 2000
The "official battery" idea would also help to check the "is the battery easily removed" item from the inspection, plus, 130 is a nice round number to play with, eh?
Mentor
Brazilian Machine
Team # 383
Unread 05-09-2003, 12:45
Software Engineer
Rookie Year: 1995
It's pretty easy to tell just by looking at the battery compartment on a robot if it's easily removed. However, an "official battery" won't really solve any problems - when you have 4 or more weigh-ins occuring at the same time (some regionals have 2+ scales, the Championship has at least 4 scales), you'd need 4 "official" batteries. And guess what? It would be very likely that there'd be minor variations between the 4.
In that regard, the scales at the Championship seemed to vary by up to 1/2 pound anyway, so there's already a lot of "slop" in the whole weigh-in process. I don't have a problem with people weighing in with the lightest battery they have (as long as it's still a legal battery). There's no rule against it and it only gains them a marginal amount of weight anyway. If there really are teams that would stoop so low as to weigh in with a hollowed out battery, then those teams will find a way to cheat one way or another, making this somewhat of a moot point.
Unread 06-09-2003, 10:11
Andrew Andrew is offline
Andrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to allAndrew is a name known to all
I think we should weigh in without the battery and change the weight limit to 55 kg.
Unread 06-09-2003, 22:56
Don Taylor Don Taylor is offline
#0343 (Metal in Motion)
Don Taylor is an unknown quantity at this point
Batteries
I would say without or at least FIRST should have a 'Standard' battery weight. We used 8 batteries last year and the difference between the lightest and heaviest was almost 1 lb.
DET
Team 343
Unread 07-09-2003, 04:26
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Rookie Year: 2000
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
Re: I must admit...
I think many teams did this exact thing. Using a "lighter, Real Battery" is much different than a "dummy". It's completely legit but at the same time unfair to those teams who get stuck with the heavier batteries.
I have seen a ~2lb difference (12.2lb - 14lb) between some batteries. 2lb's is a lot of speed holes if you don't have the "right" battery to weigh in with.
My suggestion:
Rule: Battery must be easily removed in under 15 seconds.
Reasons:
1) Very few designs have broken that
2) Easy for battery removal weigh in after Systems check.
Team shows up, does all the tests (lights, air, etc.), then gets timed for battery removal, then weighs in without putting the battery back in.
This alleviates the 'dummy battery' problem, battery weight flux problem, and gives grounds for "changing" weight limit. Be it, "lower" to 120lbs [no bat] or "keep" at 130. (Keep in mind 12-14lbs + for battery when on field)
Unread 07-09-2003, 13:04
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Team Role: Coach
Rookie Year: 1996
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
battery
The weight of exact same year, same model batteries will vary from 13.5 to 14.2.
I have heard of some rookie teams that weigh in with a "Dead" battery to save weight. That is what the veteran teams tell them to do.
Mike Martus
Unread 07-09-2003, 21:40
dk5sm5luigi's Avatar
dk5sm5luigi dk5sm5luigi is offline
AKA: Nick Galotti
FRC #1735 (Green Reapers)
Rookie Year: 1997
dk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud of
Send a message via AIM to dk5sm5luigi
If any of you remember when we moved from the drill batteries to the current batteries the weight limit was increased 10lbs to be able to keep the weight limit the same. So there is no real reason to change the weight limit or weigh in without a battery.
Team 1735 Green Reapers: 2005-Present
Team 190 Gompei: 2001-2005
Team 155 Technonuts: 1997-2001
http://www.first-a-holics.com/
http://www.findrobotparts.com/
Unread 07-09-2003, 22:51
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: Batteries
DET
Team 343
As I understand the rules, that would be illegal, since you were only allowed to compete with the two 2003 batteries that were provided in the kit, irregardless of how many 2003 batteries you may have bought.
P.S. If you get to weigh in without the battery, people will just add 10 lbs more stuff on their robots, and the point is defeated.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 07-09-2003, 23:00
Gadget470's Avatar
A Fire Outside
Rookie Year: 2000
Re: Re: Batteries
No.. the POINT of weighing without the batteries is for equality. As has been stated by a few people, not every battery has the same weight.
130lbs = 130lbs with battery.
130lbs with battery = 116-117 lbs of materals + 13-14 lbs battery.
Has your team ever had to make speed holes to cut a 1/2 lb? Why do that when you can grab a different battery and problem is solved? That's what many teams do. Weigh in with a lighter battery, inspect at 130lbs, then go in to the field at 131 lbs.
1lb can make the difference between an assembly working and not working. I say.. make it fair for all.
  #15   Spotlight this post!
Unread 07-09-2003, 23:38
Unsung FIRST Hero
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Rookie Year: 2000
JVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond reputeJVN has a reputation beyond repute
Re: Re: Re: Batteries
Brandon, this is a very good point.
I guess I didn't really understand "what all the fuss was about" until you phrased it like this.
I wonder if FIRST has ever considered this?
It seems like a trivial issue, but there is a definite something to it.
John
In the interest of full disclosure: I work for VEX Robotics a subsidiary of Innovation First International (IFI) Crown Supplier & Proud Supporter of FIRST
running bot off car battery? Trashed20 Electrical 25 06-06-2003 12:57
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
connecting to the battery ahecht Technical Discussion 1 25-01-2002 17:15
